Question about Canon PowerShot A95 Digital Camera
The following has only just started happening - Still images are captured in a very grainy and washed way. Where as captured video footage is fine. Please help.
    Scholar:
  • 105 Answers
The Canon A95 has been known for taking noisy and grainy photos. Try using a low ISO setting of 50 or 100 to see if that helps. Using auto ISO or ISO above 100 will put more noise/grain in your photos. Also, always shoot in the best lighting situation possible. The more light the better. You can always improve your photos with good editing software too.
I hope this helps and good luck!
Posted on Nov 18, 2009
Image being Captured/Recorded is in Gray Scale (Black and White
Not knowing what capture card you have, I can only guess that you are using the componet video input to the capture card and the composite video out of the Xbox. If you are using HDMI, it could be a bad HDMI cable. This link:
https://support.xbox.com/en-US/xbox-360/console/connect-xbox-360-console-tv
might be helpful in figuring out your issue.
Nov 04, 2017 | Pinnacle Computers & Internet
How can i edit the video if i finish filming
Assuming that you want to do your video editing in the PC rather than on the tape.
1.Your PC must have video capture device(either built-in or add-on).
2.Properly set your video editing software to able to capture video form your device.
3.Connect your camera to your PC in regular manner,like when you connect it to your TV.
4.Have your camera in PLAYBACK mode.wind the tape to the beginning of the footage you want to capture.
5.Open your editing software.turn on capture mode.
6.Start capture.At the same time,start playing back the footage on the cam.
7.When all footage were captured,click stop capture.
8.Start your editing work.
9.when complete,save it to some uncompressed video format like *.avi for later burning to DVD or converting to other format.
For beginners,I recommend Windows Movie Maker video editing software that should come bundled in almost every computer.It's fast,simple but effective enough for home-movie work.
BTW forget the old-school Linear Editing (on the tape) thing.It's slow,complicate and much less flexible than Non-Linear method.
Aug 07, 2010 | Sony Handycam CCDTRV118 Camcorder
Showbiz DVD 2: Can see the footage live but can't capture it
Try using another one, like hypercam 2. Or Camstudios. They probably works.
Aug 06, 2009 | Computers & Internet
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
How to overcome Grainy photos on some in door shots with my Canon A710
The reason for this is that the auto scene function chooses which ISO (light sensitivity) is needed to have a fast enough shutter speed to capture a still image (instead of a ghosted image). There is no way to change this. You can switch modes to P and specify the ISO you want to use (100-200 will give you a clear, non-grainy image, 400+ will be grainy). To capture a still image in low light with a low ISO, you need to use a tripod. Hope this helps.
Sep 22, 2008 | Canon PowerShot A710 IS Digital Camera
JVC GR D250U
This camcorder should not require a driver in order to capture the footage. Start up your capture software, power-up the camera in VCR mode and then connect the Firewire cable. It should then allow you to playback the tape and capture the contents.
Here is the manual online:
http://resources.jvc.com/Resources/00/00/94/LYT1353-001A.pdf
If you need a simple program to capture the footage look to: http://www.virtualdub.org/
Your video-editing software (including Windows Movie Maker) should also capture the footage.
Nov 17, 2007 | JVC Everio GZ-MG21 Camcorder
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Canon PowerShot A95 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
