Question about Compaq Presario Notebook
Hi there i have a Hp Compaq presario cq50 and it wont wont boot to bios i am getting black screen i removed the battery but nothing
  • 1 more comment
  • touseeffaroo Nov 18, 2009
    thanks guys but i am not getting ne thing on the screen its just black. i can hear the fan and the LED for power turns on but the LED for hard disk doesn't.
    hey man thanks but laptop is showing me nothing its just a black screen.
  • Dick
    Dick May 11, 2010
    Hi, did you hold down the "f8" key at startup to see if you can run "safemode"? If not and you can't open bios setup maybe the hard drive is bad.
    Sniper:
  • 70 Answers
Hard Drive is bad and probably needs to be replaced.
Good Luck...
Posted on Nov 18, 2009
    President:
  • 2,049 Answers
You don't mention any beeping on boot... see if any of these apply.
There are a number of beep codes you may experience:
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem
A two-tone siren, generally caused by overheating or out of specification voltages.
Four beeps then machine shuts down. This is because these version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header.
  • 65 Answers
You can hit the F2 button, F10, F12 or Delete button when it boots up and it will go into the bios.
Compaq Presario CQ50-103NR Notebook PC stuck in sleep mode
Try and perform a Hard Reset onto your laptop.
Performing Hard Reset
1. Turn off PC
2. Unplug both battery and ac adapter
3. Hold Down on the power button for 30 seconds
4. Plug everything back in and turn it on.
When you are back at your desktop screen, change the sleep mode and display settings to 1 minute to see if you can wake it back up.
If not, then load into your BIOS by pressing F10 during boot up. Once in BIOS, press the F9 key and select "load defaults". Once you load defaults, press to F10 key again to save changes and exit. After that, search the hp website using your product # on your laptop to see if there are any BIOS updated for your product.
Aug 13, 2012 | HP Compaq Presario CQ50-103NR Notebook PC
I have a Compaq CQ50-210. Problem with the HP COMPAQ Presario CQ50-210US NoteBook AMD Athlon X2 QL-62 15.4' Wide XGA 2GB Memory 160GB HDD... I have a Compaq CQ50-210. When I try to boot it, the screen...
Power up the external monitor first and then boot up the laptop, the video info will automatically divert to the external monitor.
If you do not see a Windows image on the external monitor then it is definitely a motherboard issue, because the video card is built in on the motherboard.
The Video card uses shared RAM (part of the RAM module/s ), try re-seating the RAM modules, also test the RAM modules.
You can test the hard drive by removing the hard drive and connecting it to an USB hard drive adapter, then connect the adapter into a working computer's USB port. If the hard drive is OK, this computer will see it as an external storage device and you can open the various folders and files on the hard drive.
Dec 12, 2010 | HP Compaq Presario CQ50-210US Notebook
Need CD to Format my HP COMPAQ Presario CQ50-21OUS
hi sir..There's a formatting option available during the install. Just boot from the Vista CD and select the partition where the old installation is. Windows will do the formatting for you. if you don't have vista you can download it from the following site and then boot your system
http://www.softpedia.com/get/Others/Signatures-Updates/Windows-Vista-Service-Pack-2.shtml
Feb 10, 2010 | HP Compaq Presario CQ50-210US Notebook
How can i brake the password on my laptop presario cq50
passowrd for windows or password in bios , if password windows u to soft password recovery and boot from cd to remove.
If pass bios u can't , much sent to brand to do
Jan 18, 2010 | HP Compaq Presario CQ50-140US NoteBook
FS050UA , COMPAQ PRESARIO NOTEBOOK PC CQ50-210US the screen has lines and a black spot
Turn on the notebook and press F10 to get into BIOS screen. Even if the lines and the black spot appears then the issue is with the internal hardware of the notebook.
To check further connect an external monitor to the notebook and press Fn and F4 keys on the keyboard to get the display on external monitor. If the external monitor display is fine then the issue is with the LCD screen or else the issue is with the Video card of the notebook.
Jul 31, 2009 | HP Compaq Presario CQ50-210US Notebook
MY COMPAQ PRESARIO NOTEBOOK CQ50 100EM - DOES NOT
The issue might be with the hard drive. I recommend you to test the hard drive.
If the hard drive test fails, then it is confirmed that the issue is with the hard drive of your notebook.
Click on Testing a hard disk in HP notebooks in the below link to test your hard disk:
http://notebook-solutions.blogspot.com/2009/06/all-about-hard-disks-in-laptops.html
You may also try the steps in the below links:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=23287&lc=en&dlc=en&cc=us&product=3752686
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops
Jun 27, 2009 | Computers & Internet
Not booting up; stopping at white Compaq screen
Take out the hard drive. Then turn the notebook back on and see if it goes past the Compaq screen. If it does then you know your hard drive is bad and it would have to be replaced. It could be shorting out the motherboard.
Jan 29, 2009 | HP Compaq Presario CQ50-211NR Notebook
Bios chip failed
open the back side ten remove battery.then refixit after clen dust from it.
if problem stilll then remove cmos cell for 15 minutes then it reset .
Jan 07, 2009 | Compaq Presario M2000 Notebook
NEED APPARENTLY TO CHANGE MY BIOS PASSWORD
You can try using this to Reset / Remove this BIOS Password >
http://www.ntfs.com/boot-disk.htm
Nov 24, 2008 | Compaq Presario Notebook
Compaq Presario Notebook Logo
1,542 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
