Waste tank near full - Computers & Internet
  • rbdDick Jan 10, 2008
    this problem is for a Canon Multipass MP390 printer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Here is the procedure, it is very lenghthy, and you must be mechanically unclined or give it to someone who is.
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer. This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models. LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on. You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-) Here's the fix: The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works. Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur. But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you. You may RESET the printer code first if you like or do it after you clean the pad In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset. This is the correct code procedure for resetting the Canon MP370 (and hopefully other similar designated models
  • 111) Printer on, press Additional Functions, Scan, Copy, Scan. Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
  • 2) Select Test mode which is like the last available selection
  • 3) Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
  • 4) The menu will now say EEPRON Clear. Select Ink count which is option (0) and press set
  • 5) Select Ink count which is option (0) and press set.
Posted on Jan 10, 2008
    President:
  • 1,944 Answers
I am guessing that you are talking about a printer. If so, then which printer do you have?
  • Damen Wong
    Damen Wong Jan 10, 2008
    Here is the reset procedure for your printer.
    1) Enter SERVICE MODE.---
    By pressing menu-copy-scan-copy-copy
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [Set] key.
    7) Press the [Stop/Reset] key (returning to the state of 3)), and then press
    the [ON/OFF] key.
  • Damen Wong
    If that didn't work then try this.
    Enter Test Mode by selecting
    Additional Function, Scan, Copy, Scan,
    Select TEST MODE (set)
    Select [8] Printer test
    Select [3] EEPROM CLEAR
    Select [0] INK COUNT
    Press Stop/Reset
    Press On/Off
    Sergeant:
    Champion:
  • 347 Answers
Hi
Try this:
1 Power off printer
2 Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3 Hold POWER and Release RESUME.
4 Press RESUME twice then release both POWER and RESUME buttons.
5 When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6 Press power to set data.
7 Print away!
Let me know if that didnt solve your problem
  • Santiago Vallejo
    Santiago Vallejo Jan 10, 2008
    You can also try to troubleshoot your printer in the canon webpage.
    http://alpha03.c-wss.com/inc/ApplServlet...
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
WASTE INK TANK NEAR FULL.
see solution to INK TANK NEAR FULL SMART BASE 360
Oct 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon Multi pass F60 (waste tank near full)
Power off and on at button. If message continues it needs service.
Sep 19, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Computers & Internet Logo
151 people viewed this question
Alun Cox
David Payne
David Payne
