Question about Zebra 110XiIIIPlus Label Printer
The media is in correctly and is being fed correctly but when we sent a label from our computer to the zebra printer it will not print the information on the media. Was fine a few days ago.
    Champion:
  • Zebra Expert
  • 285 Answers
Send a test print from the driver.
check the connection configuration.
if connect with serial port (check seting from the port (THE SPEED HAVE TO BE THE SAME)
if connect with USB, if necessery, install the driver again and test.
if necessery flash the firmware and test (worst case scenario)
if can't comunicate and if using paralel port:
check if the fuse next to the paralel port is burn ( on the logic board.). replace it.
dont forget to unplug the power cable and the comunication cable.
Posted on Nov 13, 2010
Why does it print labels too the right?
might be the the way they are being fed into the machine and or the setting at the computer are not correct have you try the printer web site for phone #
Jan 23, 2016 | Zebra G-Series GK420d - Label printer -...
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
I turn on the zebra z4m and it runs the labels even with no information sent to the printer. I can not use the cancel or pause button to stop. I runs for a minute and then error condition ribbon out. I...
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at zebra.com .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
Feb 24, 2011 | Zebra Z4M Printer
Unable to print Zebra labels on a Zebra 105 SL printer. Sending the label from an I-Series computer through the EntendNet 100x print server to the Zebra printer. Does ExtendNet 100x support Zebra ZPL2...
A print server should just be a 'through-put' device, and the codes should go fine. ZPL-ZPL2 codes are subequently sent as comms to the printer port. Are you using seria; or parallel input to printer?
Yo can capture the codes to a file, and review if they are correct. The file would have to be viewed in a hex editor.(write to a file through the driver)
I routinely use different mfg. of print servers for thispurpose if the printer does not have an internal ethernet port. The only problem I have run into is a problem in network where a slow download is enountered.
Feb 11, 2011 | Troy ExtendNet 100x Print Server
My Zebra TLP 2844 is installed on the network and after extensive trouble shooting it now works. but it will not keep the print settings for label size and origination. If you change it it will print that...
If this printer is on a network, check if prints are being sent from other PC's. If the settings are different on the second PC the setting will be wiped and need to be resent again. Settings are overwritten when the following prints are sent.
Mar 10, 2010 | Zebra TLP 2844 Label Printer
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Printer is only printing on every other label.
Adjut the sensor or re-calibrate.
To adjust sensor:
Open up the printer where you put the label, where the paper is fed there is are two green levers, one that helps guide the paper (media guide) which is adjustable by flipping down and sliding that is located  on the right and another one that is ON the media assembly(media sensor) check this for a reference as to what I'm talking about, it's not for a Zebra but they have the same functions.
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Go to page 29 and magnify it(400%) to get a better look
depending on the type of labels you use is how to adjust
1- labels with a knotch on the side, sensor MUST be all the way on the left ( standing in front of the machine , for reference)
2-labels with a gap in between each one, MUST be set towards the Middle of the labels.
Adjust a little at a time to check by pushing the feed button
if this does not work it must be recalibrated.
I don't have a manual for that printer, sorry.
Oct 15, 2007 | Zebra S4M Thermal Label Printer
Zebra 110XiIIIPlus Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
