Question about Canon PIXMA iP90 Mobile Printer
How can i change or empty the ink waste absorber?
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
CowboysFanZ
  • 99 Answers
SOURCE: Canon pixma ip3000
This should do the trick!
i320 waste ink counter reset.
1. Turn off the printer.
2. Press and hold the POWER button, turn on the printer.
3. The indicator should be green.
3. Press and release the RESUME button , the indicator should be orange.
4. Press and release the RESUME button again, the indicator should be green.
5. Release both buttons.
6.Connect the printer to PC.
7.Open General Tool software,choose ¡°USB PORT¡±.
8.Choose ¡°SET DESTINATION 1 ¡±,OK!
You can download the software at: http://www.it0577.com/yezmao/i320.exe
Posted on Jul 20, 2008
SOURCE: Waste ink absorber
where can i buy canon waste ink absorber?
Posted on Oct 28, 2008
  • 32 Answers
SOURCE: indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
Posted on May 28, 2009
  • 672 Answers
SOURCE: empty waste ink absorber IP4000
I found this at the Canon website. www.canon.com
I also have a Canon Pixma, seems my turn is up and coming too.
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
Posted on Aug 25, 2009
Testimonial: "The cost to let this repair: 100-150 Euro for a five years old printer. I like the device but that's too expensive."
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste ink absorber is. full. How do I empty it?
The waste ink absorber can sometimes be removed and cleaned out and put back into place. Although it is not always easy to get at. Usually once this happens it is time for a new printer. You can also contact Canon and see if they have a replacement part for this.
May 28, 2010 | Canon PIXMA iP2000 InkJet Printer
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 11, 2010 | Canon PIXMA iP90 Mobile Printer
Full ink absorber
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Indicates waste ink absorber is almost full on cannon i9900 print
May 16, 2009 | Canon i9900 InkJet Photo Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber
You'll always find the wast ink absorber under the printer head after printer head prints and rest, there is a rubber type clip which cleans the head and the ink drips down on the cushion absorber. Disassemble the printer and remove the cushion than dip in the bucket of water until ink dissolves out of the cushion and wash under running tap until clean then dry and finish, put back the item and assemble the printer.
Nov 06, 2008 | Canon Pixma MP450 All-In-One InkJet...
IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
