Question about Acer PK13BY27110 TravelMate 270 Series Notebook Keyboard 99N3482.51D
How to change TravelMate 270 keyboard! - Acer PK13BY27110 TravelMate 270 Series Notebook Keyboard 99N3482.51D
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Dismantle Acer travelmate 270 Laptop
Caution is advised, as getting everything to work again after you put it back together is normally difficult, especially the screen. You will have to remove all the panels underneath, all screws and look for screws around the screen hinge area, with hexagon heads. There are no instructions on acer notebooks on their site for obvious reasons.
Posted on Mar 18, 2007
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
How to replace batteries in batterypack of travelmate 270?
http://www.battdepot.com/us/model/Acer/TravelMate+270.aspx?gclid=CJD2oLTw_L8CFQmoaQodn2EAQw
Aug 05, 2014 | Acer TravelMate 270 Laptop Charger...
I updated the BIOS of my Acer Travelmate 270 to the last version. Now the wireless is no more activated by the dedicated key on the keyboard. No other Fn commands are available. It was not possible to save...
Hope you were not updating a wrong BIOS, I can see from their support center, there is no available update BIOS for Acer Travelmate 270..See here for details.
Aug 06, 2011 | Computers & Internet
How to remove keyboard to change cmos battery for Acer TravelMate 529ATX PC
I have an Acer travelmate 529ATXV and need to change the CMOS battery. I think it is under the keyboard but I am not sure how to remove the keyboard. Any help would be appreciated.
Mar 08, 2010 | Acer TravelMate 529ATX Notebook
Lose TravelMate 270 Series Notebook..bios paswoed
In order to remove password an (educational) solution is to open your laptop back with a screwdriver carefully and remove the bios battery (its a small silver colored round one) and put it back after 5-10 minutes. Then you can close the laptop back and access the bios setup utiliy by pressing the f2 or the f number displayed on startup and replace or deactivate the password. Another solution is to use a backdoor password according to the manufacturer and deactivate the password (search googlefor it) or use a small software utility like !BIOS if i remember correctly to retrieve the password but it may take some time. I hope that helped!
Feb 08, 2010 | Acer PK13BY27110 TravelMate 270 Series...
Random missing letters on my acer travelmate 4010. I change t kb
May be you would have replaced to top layer of the keyboard. But what about the circuit board..? Even i had similar problem and i had to replace the complete circuit board..
Sep 22, 2009 | Acer NSK8458AN Keyboard
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Memory
The compatible ram for your travelmate 270 ram is 256MB PC-133 SDRAM DIMM Memory Module.
This information can be found on Acer website.
If this solves your problem, please mark this as Solved.
Thank you
Oct 12, 2007 | Computers & Internet
Acer travelmate 270
I had the same problem and it was my battery - i would strongly suggest getting a new one, doesnt need to be an ACer - it could even be a generic one- just as effective.Try www.cellphoneshop.net, they sell cheap batteries.
Aug 31, 2007 | Acer TravelMate 270XV Notebook
Mar 18, 2007 | Acer TravelMate 270XV Notebook
Acer PK13BY27110  TravelMate 270 Series Notebook Keyboard 99N3482.51D Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
