Question about Dishwashers
I have an 2002 Eclipse with a locked out radio. The dealer told me to turn the key to on w/o starting the engine, turn everything on and in an hour or so the radio would rest. After 2 hours and a dead battery the radio is still locked. I tried disconnecting the battery for a few minutes and that did not work either. Do you have any ideas?
  • 863 Answers
Call the Mitsubishi 1800 manufacturer # and give them your VIN so they can give you the unlock code for the radio.
Posted on Nov 18, 2009
Installing push rod Mitsubishi Eclipse
The engine is a overhead cam engine so no push rods are fitted
the first thing to check will be the starter motor solenoid then the starter motor for operation
anything else will require the engine to be removed to check the timing and why the engine won't crank
Sep 07, 2017 | 2002 Mitsubishi Eclipse Spyder
2002 mitsubishi diamante. I go to start car and the engine turns over then shuts off as if it isn't getting any fuel. Try to start again and it won't start at all. If I let the car set for a few hours it...
no the keys can go wrong so try the spare key ,contact with a body scanner or even a mobile phone can cause key problems if its in the smae pocket .try the spare key
Apr 25, 2011 | 2002 Mitsubishi Diamante
2002 Mazda Truck Ignition Problem. Security related?
Mazda does have a Electronic Code Keys on certain makes of there autos could be that your problem key is not turn on key only emergency key for when you have locked your key inside the truck you have to pull the papers togather for the truck and head on over to a mazda dealer they might have to make a new code key but without all the papers stateing you are the owner they can not help you do to auto theft the key wont be cheap either it could cost up to 150$ maybe more
Apr 01, 2010 | 2002 Mazda Truck
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
2001 mitsubsi eclipse enter car radio wrong code 3 times
call 1888mitsu2001, choose option #4, then hit * (star). give the operator the last 8 numbers in your vin and they will provide the radio code for FREE!
DO NOT PAY FOR THE CODE ONLINE OR GO TO THE DEALER (they will also charge you).
- you will also need to provide the serial and part number of your radio (takes about 5 minutes to take apart an eclipse dash...1 screw in the bottom of the HVAC panel) if you call the 1888mitsu2001 it will provide basic instructions on how to accomplish this.
- if your radio says "off" (meaning you entered the wrong code too many times) you need to put your key in the ignition and turn it to ACC mode for approx. 45min - 1hr and then your radio will say "code" at which point you can enter the code to unlock the radio.
Jun 02, 2009 | 2001 Mitsubishi Eclipse
Audio car security code is locked
I have the same year car. Mechanics screwed up my radio when they disconnected the battery doing other work. Try this....put your key in the ignition and turn it to the "ACC" position so that the dashboard powers up, but don't actually turn the engine over. Then you wait. The car has to sit like this for 45 minutes to one hour uninterrupted, so bring a good book:) After the hour is up you should see the radio screen go blank. Once that happens, it should be reset so that when you turn it on you should get the "Code" message again. From there you get 3 new chances to re-enter your code correctly. This worked for me, it should for you too. Hopefully it will save you a costly trip to the dealership for such a simple fix. Good luck!
May 16, 2009 | 2002 Mitsubishi Eclipse Spyder
Need car stereo lock code mitsubishi spider eclipse
I've read that will work ok. The radio will change from locked to being ready for the code. Make sure you know the procedure for entering the code.
Apr 27, 2009 | 2002 Mitsubishi Eclipse Spyder
Radio code for 2002 mitsubishi eclipse spyder needed please!
A bit of info....if you try to enter codes three times, you radio will go to lock...as far as I know, only a dealer can help you with that problem...
Feb 01, 2009 | 2002 Mitsubishi Eclipse Spyder
2002 explorer radio not working
From LustyKid:
Steve:
Suggest you read th manual on the radio. Some radios you have to push in the on off button until the enter code window appears.
In other words push in to turn radio on and hold it in that position until the code window appears in the screen. Then enter code.
Never heard of disconnecting the battery to clear the code. All that does is tells the radio that an attemp was made to steal it, thus regenerating the lock 10 code. What it does clear is the ECM Module codes. Who was the dumbwit at the dealer that told you that? He needs to be sent back to school.
Dec 07, 2008 | 2004 Ford F150
Ignition key
I've found that the steering lock on some vehicles will interfere with the ignition lock and the steering wheel may have to be rocked to find the right position.
I think the purpose of this was to ensure that the steering lock is engaged before you can take the key out; don't ask me why - if the key is out and anyone tries to steal the car, the steering wheel will find the pin the first time the wheel is turned 90-180 degrees anyhow.
Oct 26, 2008 | 2004 GMC Envoy
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
