Question about Nintendo DS Lite Console
Ds lite has broken on right hinge - can I get this repaired or should I buy new casing and how easy is it to put into new casing ?
  • 87 Answers
I have chaged a few casings and to be honest if your not very careful there are many fiddly parts that can be damaged very easly if your not technically minded send it to a pro
Posted on Nov 18, 2009
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
Nintendo ds lite
It's not easy at all. My company does repairs on PSP, XBox 360, PS3, Wii, and PS2. But we don't touch DS Lites. The following company will do it for you at a reasonable cost:
http://www.consoledude.com
They do all of our DS Lite repairs!
Also make sure you get an OFFICIAL Nintendo shell case. Some of the aftermarket ones don't fit properly. The following website sells the shells:
http://store.richspsxparts.com/newcoornidsl.html
Apr 14, 2010 | Nintendo DS Lite Console
Lid support broke
Not much info but if you mean the lid on your DS falls backward when opened then one of two things has happened either the small barrel lock in the hinge has broken, this is rare. Or you have broken the hinge allowing the barrel lock to rotate in the case.
The barrel is cheap and a very easy fix by opening the case removing the led lens holder then change the lock. If you have broken the hinge you will need to replace the case, tricky job requiring patience especially when transfering the top screen to the new case. Watch a few you tube instruction videos to get a better idea of whats involved.
Jun 10, 2009 | Nintendo DS Lite Console
Ds lite hinge is broken is there an easy fix Right Hinge Broke, Screen Flaps instead of clicking and occasionally goes blank.
beeabe,
I'm sorry to tell you but there is no *easy* fix. If you've had no experience taking apart and assembling a Nintendo DS, I advise you NOT to start with your one and only. It's so easy to rip the LCD cables because they're so thin and you'll have to go buy another.
There are two ways to fix this... Super glue / tape it as much as you can , or send it in for repair or find a local Game repair place.
To fix a broken hinge on a DS, it requires you to disassemble the WHOLE thing. Which sucks when just starting out.
May 30, 2009 | Nintendo DS Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
There web sites where you can get a new case for your DS. When searching try using : nintendo ds lite replacement shell or nintendo ds light case modding
Feb 25, 2009 | Nintendo DS Console
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Dec 15, 2008 | Nintendo DS Lite Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
63 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
