I have a ? near full waste tank and others said to try and unistall and reinstall the printer. I have never done this so I need step by step directions...currently cannot print
  • Jim Keysor May 11, 2010
    What kind of machine?
  • Adorjani Laszlo May 11, 2010
    Precise the your copier models and describe the problems.
    Problem Solver:
  • 7 Answers
The waste toner tank is a consumable part that fills with unused toner and needs to be replaced occasionally. Check your manuals for the location of the waste toner tank
Posted on Dec 13, 2009
Hi my printers saying ink tank is nearly full contact canon press resume to continue printing can i solve this problem by myself
The inks tank that it is referring to is the waste ink tanks, which are sponges.
Yes it is possible to do the job yourself if you are up to it.
What you will need to do is remove the cover of the printer, usually some screws need to be undone.
The the sponges need to be removed and rinsed in water, use latex gloves as you don't want the ink on your hands. Be sure sure to wear old clothes.
The sponges are located on the right hand side of the printer, usually around 4 or 5 packed together.
Once they are cleaned of ink, let them dry in the sun.
Then reinstall them, and reassemble the printer.
Once all that is done you will need to find the Canon, resetting software. It is difficult to find, as it is meant to be used by printer Technicians.
Reset the waste ink counters and you printer will be back to normal again.
The other option is to get a Printer Technician to do the job for you.
Thanks
Till next time!
damnor01
Apr 13, 2011 | Canon Pixma iP4500 InkJet Printer
WASTE INK NEAR FULL WHAT IS THE REMEDY
4 step to Reset waste ink tank counter CANON
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Jan 21, 2011 | Canon Office Equipment & Supplies
Waste Ink Near Full on Canon MP730
I dont know the exact process that I have done before, however the trick is to zero your page count, and this worked twice for me. The printer figures your waste ink reservoir (actually a sponge) is near full by a page counter. There are articles out there on how to repair this physically but please dont go there, get a new printer or even better an less used MP730.
Mar 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
A message that the waste ink absorber is full - need replacement. printer doesn't print.
Hi
Try this maybe work
Canon IP 1500 waste ink tank full reset
STEP 4:- Press the POWER button again"
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 17, 2010 | Canon PIXMA iP1600 Printer
Waste ink near full
Here are the code for it
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 26, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Office Equipment & Supplies
Canon Multi pass F60 (waste tank near full)
Power off and on at button. If message continues it needs service.
Sep 19, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
42 people viewed this question
jasbo
jasbo
