Question about Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
Left input for loudspeaker is dead? speakers both work out the left but neither on the right. can I fix it myself? marshall mg250dfx thanks
    President:
  • 1,137 Answers
It sounds like the speaker output jack is broken or it has come unsoldered from the circuit board. You can fix this if you have enough electronics experience but you have to be very careful as components in an amp can carry a lethal charge even after being unplugged. You can partially discharge the capacitors by unplugging your amp from the power source with the speaker plugged into the working jack and set at a low volume while turned on ( not on standby ). If you feel at all uncomfortable attempting the repair yourself you are far better off taking it to a repair shop preferably one with experience with Marshalls. The same is true for other brands as well. Please let me know if this helps.
Posted on Nov 20, 2009
Testimonial: "thats what i figured thank you sir:)"
  • Joshua Feb 09, 2011
    The marshall MG's and AVT amps all use the same TD7293 IC and the terrible cliff jacks. The inputs/outputs get gummed up or loose and start blowing fuses and sometimes even starts blowing the power ic's. I recently had to rework mine due to the exact same reason! Be very aware of the cliff jacks on these amps ... they even cause weird problems because they are used for the speaker output 1/4" as well.(the two or one 1/4" outputs on the back of amp that are usually red colored.)
    Good Luck!!!
Amplifer input mg250dfx
No, these pedals work only with the FX range not the DFX range
Aug 29, 2013 | Marshall Amplification Marshall PEDL90008...
The part connected to the fan started smoking
Usually an aluminum heat sink is connected to the fan or near it and an amplifier chip/stick is on that. If that is what smoked, you need to take it in for replacement. Continued powering of this could damage the speaker.
Feb 11, 2011 | Marshall Amplification Marshall MG250DFX...
The treble knob for the clean channel broke off and now my clean channel doesn't work at all
Chaances are the potentiometer element was fatally damaged by the force when the knob was broken off.
You will need to have the unit serviced and getting the correct part is important to match the shaft, mounting, etc as well as the electrical characteristics.
The clean treble control is a 20K ohm, "B" taper pot (audio). ALL the signal for the clean channel goes through this so if pot is destroyed, clean channel will be dead.
Best thing is to call Marshall "parts" and get exact replacement. Note that sometimes the circuit board is cracked as a result of these accidents. This unit looks like the controls are VERY vulnerable to damage. I would make a cover to prevent damage from handling.
Another thing is to ALWAYS loop your guitar cable through the handle so tripping over it won't break the input jack which is a COMMON occurence.
Feb 07, 2011 | Marshall Amplification Marshall MG250DFX...
When turning my Marshal MG250 DFX on, there is a terrible buzzing sound. I have tried it on different speakers and the buzzing still occurs. It does not change in volume when i adjust the volume. Whats the...
This is likely a filter capacitor issue. The right tool to troubleshoot is an oscilloscope. This could also be a failed power amp that is driving high DC current with ripple into your speaker. This can permanently damage the speaker. Repair this before using it.
Jan 13, 2011 | Marshall Amplification Marshall MG250DFX...
Ive just purchased a marshall mg250dfx amp and when i play the volume cuts down low and then back up again like its fading in and out every so often
Since you just purchased this, verify that your guitar and cables are good on another amp and if they are good, then exercise your warranty on the Marshall.
Connectors and cables for guitars are chronic problems so verify they are good to avoid looking foolish.
Jul 06, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall MG250dfx's sound fades out
I have read that the problem is in the FX send/return jacks which oxidize if not used much. All you have to do, apparently, is ram a jack plug in and out a bunch of times. This breaks up the oxidation, and allows the amp to work properly again.
Feb 26, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall MG 250dfx head gone bad need help thanks
Ok guys, read your your posts and i have to say that ive experienced the same symptoms with my dfx250mg. I am a bit of an an adventurer, so i decided to take apart the head and diagnose the issue myself, this is what i came up with. The sections R107 and R96 of the large circuit board have overheated (likely linked to the faulty cooling fan of this particular model). Anyways, i reconnected them temporarily and the problem subsided. Now to resolder and test the results.
Feb 04, 2010 | Marshall Amplification Marshall MG250DFX...
I have a 30th special edition,,1962,,1992 marshall amp and want to know how to set up,,has jack plug in back,,not sure where it goes,,??
Well if there is anything you need to insert into the effects loop IE, wah pedals, noise gates etc etc the return is the output of the effect and the send would go to the input of the effect. As far as inputs those are all on the front panel.
Jan 08, 2010 | Marshall Amplification Marshall MG250DFX...
One of My speakers does not work, When I switched the speaker wires the problem followed. I believe maybe a blown channel. """please help"""
Yes, one of the power amps has probably failed. If the channels are seperate, then another possibility is a bad input connector. These do get broken when cables are tripped over.
Nov 08, 2009 | Marshall Amplification Marshall MG250DFX...
Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier Logo
279 people viewed this question
Top Marshall Amplification Music Experts
matt martin
matt martin
Vito Vacirca Jr.
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
