Question about Sharp AL-1655CS Laser Printer
Copies My Sharp AL-1655CS will only make one copy at a time...also the power save indicator light is staying on all the time.
  • 417 Answers
I can't remember but there should be a button with the name above it No. of Copies press this then you will be able to enter 1-99 copies. The energy saver you can adjust within the menu to longer or not come on at all. This will be in your manual.
Thanks J
Posted on Jan 12, 2008
I have a Sharp AL-1655CS and when i make copies, the copies are really dark. For example, the white areas come out gray and dark. How can I fix this problem?
I would try a different toner cartridge or possibly a drum cartridge. Have you had the machine serviced at all? When?
Feb 14, 2011 | Sharp AL-1655CS Laser Printer
Copiers Sharp AL-1631 AL-1641CS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
on Mar 14, 2010 | Office Equipment & Supplies
What is the drum number for copier AL-1655CS
Here is where I get mine:
Or if your copies are fine then you can reset the drum indicator by using this procedure I have posted here at Fixya:
If you use it, please remember to retun here and leave feedback.
Thank You for using Fixya.
Wheatland Services
Dec 22, 2010 | Sharp AL-1655CS Copier
My boss has a Sharp AL-1655CS Copy Machine and it makes this awful, screatching noise when I try to copy anything. Now the System Error Code L1-00 shows up. Not sure what to do.
Your problem on scanner unite.May be your copier is now lock position.
Solve:Unlock position.Left side under copy Board.Then solve your problem.Or study your copier user manual.
Jan 12, 2010 | Sharp AL-1655CS Copier
Makes noise and will not copy
Check the scan head lock. It can easily be locked or unlocked. It is used to protect the moving parts inside the machine when it is moved/transported. Someone in our office was just making copies and ttapping their fingers on it and they locked it without even realizing it. it is under the top of the machine where the paper comes out. sometimes they are a slide or turn knob.
Dec 30, 2009 | Sharp AL-1655CS Copier
Error code E7-11
CCD drive circuit (CCD PWB, ASIC harness) trouble
Copy lamp lighting trouble (Copy lamp, inverter PWB)
OR the scanner shaft is dirty. Clean it and re-oil it with 3n1 oil.
Jul 17, 2009 | Sharp AL-1655CS Copier
My AL 1631 cycles on, light comes on but won't move or copy
Toner is running low. Light come on to say the machine is adding toner. Soon it will come on and stay on.
Jun 08, 2009 | Sharp AL-1655CS Copier
Sharp AL-1655CS
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display1.gif should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies1.gif.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jan 07, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
