Question about HP LaserJet 3600n Printer
Hello, REF - HP3600n when the black toner cart ran out it was halfway through a job, this then caused a Paper Jam. I installed the new cart but every time we print there is a thin grey line down the centre of the page. I have ran the diagnostic and this happens with every colour
Bubbabear64
  • 2794 Answers
SOURCE: hp 2300 new cartridge printing black lines
There good printers its just who you use to get the cartridges from. We sell some but there not refills and we have good prices if your interested.
Unlike Ghana our can be returned if they don't work.
Posted on Jun 24, 2008
SOURCE: Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Posted on Sep 18, 2008
SOURCE: A very thin light blue line appears on all printing jobs
When vertical streaks or bands appear on the page, it means that one or more print cartridges might be low.
Posted on Dec 16, 2008
yooperbud
  • 8637 Answers
SOURCE: hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
  • 192 Answers
SOURCE: Lines down the paper HP 4600DN
The actual problem is that the cleaner stage of laser printing may not be functioning correctly on the drum.
One thing you can do is purchase specific sheets from staples I believe. They are meant to be used in the cleaning cycle of the laser printer. Do this first. If this doesn't work, then the drum needs to be replaced.
Posted on Jul 25, 2009
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx 4300 error paper jam1 install toner
Sir
there is a sensor lever at middle of the engine base, under the toner cart. when the cart inserted it has to pushed half and other half is for paper jam-1 error.
Pl. check the lever-check the smps photo interrupter-check the mech alignment of the lever- also check the cart hold lever(left-right) pressure (found on top of the engine base).
Thanks.
Dec 19, 2014 | Samsung SCX Office Equipment & Supplies
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Hello, I was printing a 30 page document on my samsung CLP300 printer and it quit printing after 20 pages. It does not indicate that it has a low ink cart. and I see no signs of a paper stuck anywhere (I...
There are many reasons that causes this printer to stop printing, like empty toner cart, full waste toner cart, paper jam. The only way to know for sure is to use the smart panel program to see what the printer is sensing as a problem and go from there. Hope this helps.
Oct 07, 2010 | Samsung CLP 300 Laser Printer
Hello, I have a HP printer Laserjet 1522nf. I replace the old cartridge with a new one.(original) After the reaplacement on the display was writed 'instal black cartridge'. I tried with the old one...
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
Aug 24, 2010 | HP LaserJet M1522n MultiFunction Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
HP LaserJet 3600n Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
