. unable to lower or raise volume, comcast remote on olivia tv
. unable to lower or raise volume , box turns on, channels change, sound no good
  • 863 Answers
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Posted on Nov 18, 2009
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Our 52 inch samsung plasma tv makes a humming sound when on. is this dangerous. comcast said it should not be happening
Try this.....
Turn cable remote volume all the way down. Raise the volume all the way up with your TV remote. Lower the volume with Cable remote to your usual listening volume.
Feb 12, 2010 | Samsung DLP HL-P5663W 56" TV
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How can you tell if the remote sensor on a tv is broken?
First you need to check if your remote is working. You can use a digital camera to do so. First place new brand batteries in your remote and then look at the signal diode (the small transparent bulb thingy at the top of your remote). If you press the buttons on your remote you should see the diode flash. If not then there are one or more bad components on you printed circuit board or probably open circuits.
Aug 17, 2009 | Philips Magnavox Learning Universal Remote
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Black box
Good Day,
With black box, get the TV's remote and turn OFF the "closed caption". You are in the text of your cc. Good Luck, big IRISH.
Jun 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
Electro Med Services...
