I had one sony projection TV which was bought about 5 years back. now for the past weeks, my TV set started to be problematic. When I press ON button on the remote control, the light initially turned green but then started to blink (I supposed it is timer light). On the sound can be heard but then it was suddenly shut off automatically. Occasionally it worked as ordinary, but most of the time this thing happened
  • 68 Answers
SOUNDS LIKE A DLP TV AND THE LAMP IS GETTING WEAK AND NEEDS TO BE REPLACED
Posted on Nov 18, 2009
I have Mitsubishi WD62525 for the past 5 years. Last week the lamp light came on RED and I replaced it with a newer lamp and the TV still doesn't work. The RED light continues to stay on. Any ideas on what...
check to make sure the lamp cover is pressing the lamp switch in it is at bottom right corner of lamp panel, also make sure lamp is set in properly,another thing to check is the lamp cooling fan panel on right back side,remove and clean filter and replace
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Wega 42" LCD w/Bright Blue haze at bottom corner of screen
hello it sound like convergance may need setting go in to the menu click on convergance you should be able reset the picture
good luck
shaun
May 14, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
I have a ghosting problem with my Sony XBR800 TV?
Sony is saying I have to repair my ghosting problem with an optical engine for $1650 plus $395 installation. Guess life expectancy on this TV is only 5 years. I'll think twice about a Sony in the future. Our super bowl party will be great for Sony. When everyone asks "whats wrong with your TV", I'll have to say Sony said 5 years is just about right
Nov 17, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
No geen colour!but great pic and sound
sure turn up your screen control for that color slowly if color comes back then the adjustor is just dirty (no repairable) make sure you don't see milky white lines or a solid color on a blank input.
put the unit on a video position that has no source so the tv displays the input label but nothing else.
slowly adjust the screen control( behind the front grille little black box with 6 little knobs on it)
untill you start to see the coresponding color then back it off till the color is gone, you are done.
if this doesn't work then check your video path from jungle to crt output, your output chip may ne fried
Oct 07, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
5 blinks means problem in the AKB (video) and 4 blinks means problem with the verticle deflection. Try this to get the screen to display any recent faults then get back to me and let me know what it said. Press the following buttons on the remote.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Jan 13, 2008 | Sony KP-41T65 41" Rear Projection...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
