Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Hi, i'm switching to windows 7 64 bit, and i am trying to find trust 240th 64 bit scanner drivers. are there any? or is there something that can be done to make it work?
old marine
  • 2128 Answers
SOURCE: Printer won't work with windows 7 64 bit
You can download Windows 7 x64 drivers here. Be sure and download both the driver and the MP Navigator (under software).
Posted on Nov 05, 2009
MarcusVR
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Posted on Jan 16, 2010
TechSaver
  • 93 Answers
SOURCE: Windows 7 64 bit driver
No problem.
1- Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6624#DownloadDetailAct
2- Click on "Drivers & Downloads" tab
3- Click on "Select OS" and select Windows 7
4- Click on "lide20lide30n670un676un1240uvst7031a_xpen.exe7.0.3.1a"
5- Select Open or Run
Follow the prompts to install the WIndows 7 drivers
Thank you. Please feedback me :)
Posted on Jan 31, 2010
allanhunt
  • 135 Answers
SOURCE: I have canon image class MF3240 i can't make a
look for an updated driver in www.canon.com that is compatible to windows 7 64bit version
Posted on Mar 28, 2010
SOURCE: Windows 7 64-bit driver for Canon LBP-2410
Canon replied to me saying;
That printer is not compatible with a 64bit system.
Those drivers on the internet are just for 32bit, unless specified differently
Posted on May 12, 2010
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Got a HR8 Genius scanner working with win7-64 until upgraded my system to win8 - 64bit and stop working. Tried the compatibility mode and nothing... any solutions?
How to Install Scanner ColorPage HR8 Geniuns 64-bit Windows 8.1
First:
Getting Driver Genius for Windows Vista
http://download.geniusnet.com/2007/Scanner/HR8_V.zip
Microsoft reports no drivers from the manufacturer, to try luck with the driver of windows Vista, but does not explain how to make it work.
http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/drivers-for-genius-colorpage-hr8-scanner/3026b412-09db-48de-8665-6d1dda37b11d
After you download the driver, you have to run the "setup.exe" in support "Windows Vista" mode.
But before you do read the following explanation because you have to do something else before I install it, otherwise it does not work.
As I said, after trying I did not recognize the driver, I tried to take the driver manually
but windows saying that the driver was not digitally signed and you can't install if driver is not signed.
I Search the web such as disable that control and found a step in the url:
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
After following the steps I could install the scanner driver and HR8 works correctly in Windows 8.1
LAST:
Now you can run the setup.exe in compatibility mode with Windows Vista, at the end makes restart the computer,
Now you got the scanner Genius ColorPage HR8 running on Windows 8.1
Sep 28, 2013 | Genius ColorPageSlim 1200 Flatbed Scanner
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
Cannot find Driver for my Trust scanner 19200 flatbed. When i have something i get the message : cable not connected to pc.please check cable. But when i connect my scanner only to pc then i get the...
Good day rjbogaard, I believe I have found the driver you are looking for. This driver is for Easy Webscan 19200 for the Windows XP operating system. You can find the product information here at the Trust website. You will also find the manual downloads if this is the correct product. Thanks and have a great day rjbogaard.
May 13, 2011 | Office Equipment & Supplies
Can i use trust 19200 scanner in my windoes 7 laptop?
It will not work unless you have the correct drivers. However, it appears that this model only has XP drivers which will not work on Windows 7. You need at least Windows Vista drivers for hardware to work in Windows 7.
Mar 22, 2011 | Trust Easy WebScan 19200 Flatbed Scanner
Dove posso trovare i driver per windows 7 a 64-bit?
Hi tnicola5,
You may download your driver software, click this link http://drivers.downseeker.com/download/46433/trust-scanner-direct-webscan-19200-version-1.2/.
After download completed run the set-up, then follow the wizard.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 23, 2011 | Trust Direct WebScan 19200 Flatbed Scanner
I want driver for windows 7
It seems that Toshiba's latest driver for this device supports only Windows XP and Vista 32-bit.
Here are the links:
1. Scan/Print Driver, Win 2000/XP v2.30
2. Scan/Print Driver for Vista 32 bit
3. Button Manager for Vista 32 bit
Manufacturers usually drop support for older devices after some time. Specially for printers and scanners the support is even more limited; most of them (if not all of them) offer warranty of one year.
Your best shot is to try the Vista drivers. For printing you shouldn't have problems. When you install the printer Windows have generic drivers for supported (current/older) devices. This driver should work for printing.
For scanning you can try something like VueScan which is compatible with Windows 7. Toshiba devices are not in their list of compatible scanners, but you can never know...
Note that VueScan only works with SCSI, USB and Firewire connections, most wireless Canon and HP scanners (on Windows and Mac OS X only) and doesn't work with parallel-port connections.
This can be solved with a parallel to USB cable converter (be sure to check whether you need male or female parallel to male or female USB converter).
I hope this answers your request.
Nakis
Feb 16, 2010 | Toshiba e-STUDIO 120 Laser Printer
Incompatability between hp scanjet 3970 and Windows
Hi, just go to HP drivers and solutions, i have Vista 64 bits.
Rgds, Auke.
Mar 20, 2009 | HP scanjet 3970 digital flatbed scanner
Drivers for trust 240th direct wedcom gold scanner
Get it here:
http://www.driverslab.com/drivers/Scanner/Trust/240TH_Direct_Webscan_Gold_3_0-Windows_98_Me_2000_XP/2239.html
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 11, 2008 | Office Equipment & Supplies
Windows vista 64 bit driver
Hi mtrump1,
Thanks for your posting in FixYa.
The driver are available on the Canon Website, use this link to get it:
http://software.canon-europe.com/products/0000441.asp
or
For Vista 64 Bit you can try:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/CANON/Canon-CanoScan-D1230U-611c.shtml
But i think both should be compatible to run in any 32 or 64 bit environment.
Regards
ELLIN
Sep 20, 2008 | Canon CanoScan D1230U Flatbed Scanner
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
old marine
old marine
