Question about TruTech TT320
T600-D Door won't open. Only used once!
  • crash123 Feb 15, 2008
    Joe from Starlite customer service 1-612-344-4668 told me to buy a new unit and return the bad one under the new warranty. Brilliant! crash123
  • yellow mello Apr 26, 2008
    Mine will not eject the DVD. I can tell that it is "trying" to, but, unsuccessfully. I have a Netflix DVD stuck in there, and two taht are going unwatched.
I have the T600-D DVD player. The unit's door will not open leaving my movie stuck in it. I have used the equipment probably not more than 5 times. I do not appreciate TruTech not having a phone number or person that could help or give instructions when there is a problem with one of their products. When I tried to call the number listed in the warranty booklet, I was directed to call a (900) number which would cost me $9.00 per minute. This is unacceptable business ethics. I tried to return the unit to Target, but because the 90 days had passed, they could do nothing about your product. Maybe I should post a sign by TruTech items stating that you do not stand by your products, so it would be advisable not to purchase any of them.
Posted on Apr 30, 2008
Air Purifiers for Smokers
well,
The Airpura T600 is dedicated for smokers.
You can check out some good points of Airpura T600 here:
Airpura T600 Tobacco Smoke Air Purifier review
Aug 12, 2016 | Airpura T600 Tobacco Smoke Filtration Air...
Location of blower motor in 1987 t600 kw
Search Results Blower Motor (HVAC) on HeavyTruckParts.Net
https://www.heavytruckparts.net/search.php?qsearch...KENWORTH
$350.00 1993 KENWORTH T600 Blower Motor (HVAC) .... Plastic; Blower Wheel, OEM# 589540 Peterbilt, 2000 1987, All w/Bergstrom A/C 4-1/2? Dia. (CCW) ...
Search Results Kenworth T600 Blower Motor (HVAC) on ...
https://www.heavytruckparts.net/search.php?...Kenworth...T600...
Search Results for Kenworth T600 Blower Motor (HVAC) on HeavyTruckParts.Net. Easily find what you need from thousands of parts available. HTP.net has ...
Viewing a thread - Kenworth cab fan - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=447803...flat...1
Jan 21, 2014 - 9 posts - ‎9 authors
Feb 03, 2016 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
Sep 02, 2012 | 2000 Buick LeSabre
Where is the blower resistor on a 2004 kenworth t600
Hello..
I'm paul
Am been trying to locate heater blower resistor for my 2004 kw t600 for days but no luck please helppppp..
Thank you
Jun 16, 2012 | Cars & Trucks
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
My freezer has produced too much ice and now the door won't close and food is stuck in each drawer!
TURN IT OF AT WALL FOR ABOUT FOUR HOURS THEN GENTLY RUN A HAIRDRYER AROUND DOOR SEALS. ONCE U GET IT OPEN USE HAIRDRYER AROUND EDGE OF BASKETS TO FREE THEM UP.
Aug 01, 2011 | Baumatic Refrigerators
TruTech TT320 Logo
135 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
