Question about Fisher and Paykel Kitchen Ranges
Just had a new oven installed OB60SDEPM1 it isnt working went throung the insallation set-up then 30 FO appeared and only the fan is operating
  • sandraharvey Nov 18, 2009
    will do thankyou for your advice
  • 3,037 Answers
Hi, basically the following is your problem taken right from their manual. Most likely you have a faulty temperature sensor (parts can be defective once in a while) which will look like a small rod inside the oven coming off of the back wall. Since the oven is new, I would definitely have the company you bought it from replace the sensor for free or at least give you a new one as it is pretty simple to replace yourself and it should then work.
1. 30 F0 or 30 F1 appear during the cooking or self cleaning cycle
Oven temperature sensor broken or not working properly. The cooling fan stays on
and if the self cleaning cycle is in progress the door remains locked.
What to do:
1. Turn the oven function selector to 0 (OFF). A 30 minute countdown will start. If the
selector is turned and then returned to 0 (OFF) the count will start again from 30.
2. Wait for the countdown to finish.
The fan switches off and the door, if locked, unlocks.
3. Disconnect the appliance from the main electrical supply and contact the Service Center because the oven can no longer be used.
Caution: If the function selector is not turned to 0 (OFF), the cooling fan will continue to work and the oven door, if locked, remains locked.
Let me know how this works out.
Benjamin
Posted on Nov 18, 2009
Have replaced the main control board, and all the control panel lights now work, compressor comes on, fan inside comes on, but fan at bottom of refrig does not. Checked all connections and all is good....
Set you refrigerator controls at their middle settings. Put a thermometer in both sections. Check after several hrs. Freezer temp should read near 0 and fresh food temp between 38 and 42 degrees. Those are normal operating temps on most refrigerators.
Mar 06, 2015 | Refrigerators
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Our electric oven. The digital panel says "prob". Can u help
I know on residental ovens the "prob" stands for meat probe and will im not a expert on commercial ovens i suspect it means similar and if the probe isnt insalled if it has one the jack it plugs into is shorthed
Aug 03, 2011 | Blodgett Ovens
How am i going to register my genuine Windows7 Operating system throung net? i installed my OS. Windows7 more than 30 days already... are my files still intact?
Yes, they are still there. But you don't need to register it, you need to activate it. For this you must follow this
http://www.kodyaz.com/articles/how-to-activate-windows-7.aspx
Apr 20, 2011 | Computers & Internet
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
22 people viewed this question
Top Fisher and Paykel Kitchen Ranges Experts
vince
Beamvacman
Level 1 Expert
linnap
Are you a Fisher and Paykel Kitchen Range Expert? Answer questions, earn points and help others
