Question about OKI C5800Ldn Led Printer
Won't print black with magenta cartridge empty
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
No magenta ink, just need to print in black but won't let me.
Hello.
Hold down the Stop/Reset Button (it has a red triangle on it) on your printer for 10 to 15 seconds until the light stops flashing.
This will disable the ink level monitoring for the empty cartridge, but be careful not to print with a completely empty cartridge, as this can burn out the print head.
Regards GM
Jul 29, 2011 | Canon PIXMA MP520 InkJet Printer
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Won't print black because magenta color is empty
Refill or replace the empty cartridge.
When you ask to print "black", a small amount of magenta is mixed-in.
No magenta, no print.
Nov 11, 2009 | HP Photosmart D7360 All-In-One InkJet...
Magenta cartridge is empty, how can I print in
You can't.The printer need all cartridges not empty to initialized and printing.You need to replace the empty cartridges to print.
Oct 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Can I print "Black only on the Epson BX 300 F ?
Since the printer insists on having all 4 cartridges (non-empty) fitted before it will print anything, the only recourse to fitting new cartridges is to fool the printer into thinking your empty magenta cartridge has ink in it. You can do this by using a cartridge resetting tool to reset the magenta cartridge chip so it reads "full". A resetter tool can be obtained from e-bay very cheaply (£4 or less). You will find sellers who ship worldwide on E-Bay UK.
Be aware though, that if you forget to select monochrome printing, the colour ink is also used in black printing - and printing with a "dry" cartridge can damage the print head. You can guard against this by filling your magenta cartridge with distilled water.
You will also find sellers of magenta cartridges (and the others of course) on E-Bay UK who ship worldwide.
Feb 25, 2009 | Epson Stylus C86 InkJet Printer
Empty ink cartridge message
I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
Any clues how to fix this?
Jul 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
OKI C5800Ldn Led Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
