Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My frigidare stove top coils are warping (the bottom metal part that holds them up) why? My husband says they dont heat well on low and when turned up they get too hot! why?
2 Suggested Answers
RescueTech
  • 145 Answers
SOURCE: neither the stove top nor the oven get hot!
Hi and welcome to FixYa.com
First thing you want to check is the power supply (fuse or circuit breaker) to your oven.
Now, before you say "RescueTech it can't be the fuse because the indicators light up and I can set the controls!" read on-
Your range and oven elements are 220V units. This requires both legs of the 220 (L1 and L2) in order for them to heat up. Your indicator lamps and controls are 120V, therefore they will continue to work if one leg of the 220V feed is not present. It is very unlikely that all your switches and elements have failed at once. So start first at your fuse or breaker box. If you have cartridge fuses, you need an continuity tester or ohmmeter to check them. If you have breakers, there are two styles- One is a "single lever" style that controls both legs of the supply. The other style is a "double pole" breaker that is actually two separate breakers connected by a pin between them. Oftentimes one side will trip but not the other. You will actually be able to visually see this as the pin will appear crooked as one breaker is in the ON position and the other is in the TRIPPED position. Turn off the breaker (both sides will move together) and then reset it to the ON position. Now the pin should appear straight and both breakers should be in the ON position.
If the breaker seems to be fine, the next thing I would check is the terminal block where the range cord is connected to the appliance. As a journeyman technician, I often see where the installer failed to properly tighten the range cord's terminals when he/she installed the range cord. The appliance will function for awhile, sometimes for a few years even, but that connection gets HOT every time the range is used, and especially when the oven and all 4 burners are used together (Like on a HOLIDAY!) What will eventually happen is that the terminal will literally burn away and break the connection to one side of the 220. The result is anything "low voltage" on the appliance such as clock, lights, timers, indicators) will still work, however the elements will not heat up.
Before you start changing parts, check these things. I would be very curious to know how this one turns out. Just remember that the top burners and the oven have no connection to one another other than the supply voltage.
I hope this helps and have a happy and safe New Year from all of of here at FixYa!!
Posted on Dec 27, 2008
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
Oven is not heating up. Gas burners on stove work.
your unit may have a bad ignitor .. this is located in the bottom of unit most uits the inside of oven on bottom will have a metal plate that cna be removed by taking 2 screws out of the rear part of the metal panel... raise it up and you will see a ignitor under a heat shield that can be tested..it should glow bright when unit is turned on and should have 120 volts coming to it...
Feb 03, 2011 | Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Hello. The bottom coil on my oven is not heating up. How do I go about fixing this problem?
Replace the coil. It is probably held in place with a couple of screws. There will be an electrical connector behind the coil which attaches to the stove wiring.
Lowes and Home Depot usually stock these items.
Oct 14, 2009 | Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Nov 17, 2008 | Frigidare FGB24S5DC Gas Single Oven
Canning kettle
I have used a 8 qt. pressure canner (which holds 4 qt) and have done beans and venison. It also holds quarts. I also use an 8 qt. faberware kettle that holds 5 or 6 pint jars with a metal spacer from my pressure canner on the bottom. No problems for 10 years......except my self cleaning oven doesn't work but I don't think that has any thing to do with the canning on top. The bottom of the kettle has to be SMOOTH and FLAT so a regular canner (blue, ribbed bottom) won't work. Burner will come on and off.
Jun 22, 2008 | GE Profile JTP18 Electric Single Oven
OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
Jun 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
76 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
