Question about AOpen AX4SG Max Motherboard
93 camry low gas mileage just had tune up but still burns alot of gas
  • 56 Answers
Either your car is running cold,or your 02 sensor is bad
Posted on Jan 11, 2008
Volvo 850 sometimes runs rough and gets low gas mileage sometimes runs fine
tune up. Good starting point.
mass air flow sensor, O2 sensor..... could be many things.
Dec 10, 2012 | Volvo 850 Cars & Trucks
I am smelling fuel and it burns alot of gas.
Check for leaks, service engine lights since CTS (Coolant temp sensor) can cause the vehicle to run rich. Keep in mind that there is a lot of Ethenol in our gas that is lowing the gas mileage on our vehicles.The canister purge tank can cause gas smell if it isn't working right, but the computer should give you a service engine light on any of these.
Mar 28, 2011 | 1997 Ford Expedition
2003 CHEVEY BLAZER POOR GAS MILAGE Just tuned up , new wires,plugs, pvc vavle,rotor ,cap.air filter ,fuel filter, seems to run great, no check engine light, 74000 miles, new tires, only getting approx 8...
What grade of fuel are you using? There are many conditions that effect gas mileage. The way a vehicle is driven, is it shifting correctly, flooring it to get up to speed from dead stop also known as Jack Rabbit starts, driving with the defroster on when it isn't needed or the setting just above that can be used. Back in the 90's most car manufacturers made a change to their heating.cooling system that caused the AC compressor to kick in when the selector was set to defrost. This puts drag on teh motor and decreases gas mileage. Build up on valves and low compression in the firing cylinders will cause you to lose gas mileage as well. Do a compression check on the motor to make sure you don't have abnormally high compression or low compression on cylinders and use a bottle of gas treatment in your fuel to clean some of the carbon build up from injectors and valves. Also start using the Mid grade fuel. Not the High Octane in your area. In Texas we typically have 3 choices 87, 89 and 93 to choose from. Low grade is enough to run the vehicle but performance is low as well as mileage. I use the 89 octane for better performance and better mileage. The High Octane or 93 isn't really good as it leads to higher carbon build up on the valves. Also check your oil often and make sure your changing it every 4000 miles at the longest. All of this along with making sure you change the Air Filter every 5000 miles will increase your mileage.
Jan 25, 2011 | 2003 Chevrolet Blazer
I have a 1998 buick regal it has been recently tuned up was getting very good gas mileage and runnin well now it is burning more change in performance and no engine light codes
Good gas mileage on this car should be 19City 27Hwy. Gas mileage can be affected by many things. Assuming that the car has been recently tuned as you have indicated, I would: Check tire pressure first<-you'd be surprised what low tire pressure can do. Check for low oil level <-engine friction Cheap spark plugs. Let me know.
Jan 12, 2011 | 1998 Buick Regal
1996 audi vacuum hose problems,burning gas alot i
mcdevito75 here, Vacumn lines broke or disconnected will truely effect gas mileage even with the best tune up, Leaking fuel injectors also, a leak in your fuel system also, you can usually smell the gas, also a crack in the intake manifold or loose bolts on the intake manifold will create bad gas mileage, have your repair shop check all these items for you.
Feb 11, 2010 | 1996 Audi A4
Burning alot of fuel 2001 chevy impala 3.4 engine. Check engine light on. recent tune up. 95,000 miles. Car also hesitates highway acceloration. Thank you. will have to check the code(s) stored in the computer.
The check engine light is telling have a problem and fixing that problem may help with your fuel mileage.
When the check engine light is loose 20% gas mileage and have 20% higher emissions.
Oct 19, 2009 | 2001 Chevrolet Impala
I just tune up my car and know i am getting bad gas miles
The only way you can determine your gas mileage is by filling the tank then driving it down, filling it up again and dividing miles driven by gallons burned. You can't determine gas mileage by how fast the gage goes down. You may have made a mistake in your tune-up and got a couple of wires crossed. Someone may be staeling your gas.
Oct 06, 2009 | 1999 Oldsmobile Regency
Just bought a 1995 toyota camry.
Mar 26, 2009 | 1995 Toyota Camry
AOpen AX4SG Max Motherboard Logo
27 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
