Question about Vehicle Parts & Accessories
Car turns over but will not start no spark at plugs
  • 560 Answers
Need more info, car, petrol, diesel, year etc.
Sounds like a crank sensor
Posted on Nov 18, 2009
Ba 203 won't start imobilelizer has come on can't get it off how had ute 1week ford say have to to tow to them and $140.0 to go on computer is there cheaper easy way please. tony f# fords
Hi Anthony......,It's either electrical OR fuel so If you're a hands on guy then do this.... Pull a spark plug lead off a spark plug OR if it's a "COIL ON A SPARK PLUG" pull that off and put a spare spark plug into that spark plug lead OR coil, Then earth that spark plug to a clean part of the motor(make sure the spark plug is touching steel)Turn motor with the key and see if the spark plug sparks.... If it sparks then you have a fuel problem....... But if no spark then you have an electrical problem.... The links below are YouTube videos showing how to fix a car that doesn't start/cranks but doesn't start, Also there's videos down the right side of the links that may help as well...................
Fixing Car That Does Nothing When You Turn The Key
Fixing Car That Cranks But Doesn Start Up
Car Cranks But Will Not Start
May 04, 2016 | Ford Cars & Trucks
1983 Capri RS WONT START it is getting spark to the plugs and fuel turns over fine just wont start
Points or electronic ignition? Corroborator, or fuel injection? Was the car sitting idol for a long period of time, say, 6 months to more than 1 year? With a car that old, I would start with replacing spark plug and ignition wiring. Have you checked the spark plugs? Make sure they're cleaned and gaped. If corroded, replace them.
Sep 22, 2014 | Cars & Trucks
Wont start no spark on spark plug
For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
May 24, 2012 | 1990 BMW 525i
1990 Cadillac Seville won't start. Is it the electronic control module?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This For spark plug problem, click the help links provided below: ---
Car has no spark?
This will help.
Thanks.
Feb 19, 2012 | 1990 Cadillac SeVille
2001 Kia Rio, motor start very well first time after drive around 2 miles motor no start no more
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 03, 2012 | 2001 Kia Rio
Car will not start, engine turn fast enough to start. swapped relays still would not start. 2003 madza tribute.
Check if you have a spark by pulling the spark plugs and crank the car while the spark plug is on the ignition coil/spark plug wire and ground the threaded part of the spark plug and ask someone to start the car and look for a spark is a spark is present then ignition is fine. If spark plugs are wet and smell like fuel there is problem in the ignition system.
Mar 14, 2011 | 2003 Mazda Tribute
1989 Honda Prelude won't start
I suspect that your spark plug wires or your distributor is going out. Check your spark wires and distributor. To do that take out #1 spark plug wire from the spark plug. Next take out your spark plug then put it in the spark plug wire. Then turn on car and take a look at the spark plug to see if it's getting a spark. Do this with all the spark plug. If it is your spark plug wire I would replace all of them.
Jan 31, 2009 | 1989 Honda Prelude
Engine is not running
Looks like u better find a ride to work. U need spark and gas for the car to run. When u turn the key, does the engine turn over? If it does, u should check to see if there is spark at the plugs. Remove a spark plug wire, remove the spark plug (if u have an extra plug, just plug it into the removed wire) place on nearby metal surface, turn key, watch for spark at tip of plug. If u see spark, check to see if gas is getting to spark plugs. After several attempts to start, you should see gas (wet) on plugs. Let me know what u find
Nov 11, 2008 | 1992 Honda Accord
Vehicle Parts & Accessories Logo
107 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
