Question about Samsung DVD-HR735 DVD Recorder/HDD Recorder
DVD copies stop playing after 30 minutes
All DVD copies (not originals) stop playing after exactly 30 minutes, picture freezes and recorder has to be restarted. Buzzing sound increases closer to 30 minutes. Looks like copy protection but this is stupid to do in this way. Could try to update firmare from Samsung but how do you do that? File ends with UTF extension and Samsung give no help.
  • Jules61 Jan 10, 2008
    if gear is broke why original play ok?
  • Jules61 Jan 11, 2008
    The disc is not scratched. After switching off for 1 hour I can restart, move to the same scene and watch from there on. Tried different copies of different titles and all stop after 30 minutes of movie even if fast forward to say, 10 mins. Originals play OK. Buzzing seems to come from dvd part, not from hard disk because switching to Hard disk stops buzzing. Thanks for your help.
    President:
  • 4,402 Answers
Sounds like a gear is broke moving the transverse motor
Posted on Jan 10, 2008
  • Cary Farah
    Cary Farah Jan 10, 2008
    is it scratching the disc? do you know where the buzzing is comming from?
  • Cary Farah
    Cary Farah Jan 11, 2008
    ohhhh >>>> move to the same scene and watch from there on.
    I would say then you have something heating up most likely power supply.
    I would buy a can of freeze at radio shack and spay it while it happens see if you can isolate it. most likely a part that has a heat sink.
Dear Sirs, Recently, my Sharp dvd-video combi player has been encountering some problems regarding the playing of dvd's. When I watch a movie, in several occasions the movie will freeze up. And for...
the DVD unit in your sharp is a self contained unit. IT is only repaired by replacing the DVD as a assembly. the cost of replacing may exceed the cost of purchasing a new one.
The most likely cause of your problem is in the brass gear assy that runs the optical pick up in the traverse deck. IT is not an available part.
Feb 17, 2011 | Televison & Video
On one particular DVD (UP from Disney/Pixar) a certain section keeps repeating. When I stop the DVD to try accessing the root menu it freezes up and the entire sound bar locks. The only way to resolve this...
Those discs have a very strong copy protection mechanism to avoid making digital copies on PC systems but some DVD players won't play them because of that, if you have the original movie, download a copy from the internet, burn it to a dvd-r disc and play it. It's perfectly legal because you already bought the movie. The downloaded copies have no copy protection and will play better than the original.
The PHILIPS DVD-Home theater players are specially picky about non-standar disk like the one you're trying to watch.
Jan 12, 2010 | Philips SoundBar DVD Home Theater with...
I have recorded a TV programme to the Hard Drive. However - I started recording manually and forgot to stop recording. So I have a recording 30 hours long! I want to copy the first 90 minutes to a DVD....
I used the edit function. I fast forwarded to the end of the section I wanted to record. I then stop the fast forward and used the split function. This split the original recording into two parts - the first 1hr 38min which I wanted to keep and the rest. It saved as two files and I was able to copy the first part to DVD and discard the rest.
Duncan
Dec 13, 2009 | Lite On LVW-5006 DVD Recorder
Recorded DVD disc freezes up on a different DVD player
hey ,
recommendation, the disc may have an internal scratch. (meaning when its played there might be a bump or something on it unseen by the human eye)
or you can stop being cheap. and get a new one
Jan 20, 2009 | Universal Music and Video Distribution...
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
Picture/Sound freezes
This model does NOT work well with HD boxes. I would double-check the Philips website, and upgrade the firmware for device since all 3 players were doing same thing.
Aug 13, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Go Video Model # VR3930
while playing a dvd the player will pause then skipping to a later part of the movie. It does it on any disc weather it is old or brand new. I need help. Thank you
May 08, 2008 | GoVideo Go Video DVD/VCR Combo
DVD freezing
I have had the freezing problem on Sony, Insignia, Cyberhome, HP computer DVD drives, etc.
Based upon very numerous incidents (believe me, I mean hundreds) the problem occurs most frequently after about the first hour as the track moves outward from the hub (and velocity per 360 degree turning increases).(Recording is from the hub out, not from the outer edge in towards the hub). An engineer suggested that the increasing velocity creates the greater possibility of the reader "missing" a data fragment which, in turn, "freezes" the image presently in the buffer. It may "recover"
and move data along again but will probably "freeze" again.
The following definitely helps but does not always work:: Keep the track "tight" by recording actual
running time NOT longer than 30% of the maximum capacity
permitted by the selected speed. Example: On a Sony RDR GX7, I record not more than 60 mins actual time at LP speed
which, on this machine, permits a maximum capacity of 180 minutes using LP. Based on literally hundreds of DVD recordings, I can say positively that the above approach HELPS
limit the problem but it DOES NOT totally eliminate it.
I REALLY WOULD LIKE TO HEAR FROM OTHERS, PARTICULARLY PROS, WHO HAVE INFORMATION ON THIS SUBJECT. Even reduced, the problem is irritting.
busbyii@verizon.net
from my personal MiniDV travel tapes
Nov 29, 2007 | Televison & Video
Picture freezes
Is this problem happening when playing back from DVD, VCR or internal disk?
Sep 30, 2007 | GoVideo DVR5100 DVD Player / VCR Combo
Open Questions:
See all Samsung DVD-HR735 DVD Recorder/HDD Recorder Questions
Samsung DVD-HR735 DVD Recorder/HDD Recorder Logo
219 people viewed this question
Jerry Greenberg
Jerry Greenberg
