Question about Intel DG31PR Motherboard
Turn off power and reinstall the jumper in normal mode position
  • Mark Taylor
    Mark Taylor May 11, 2010
    What are you asking?
  • 634 Answers
You have installed the jumpers in incorrect way,please install with correct way.Keep one piece of jumper in certain chips to set down on mother board.
So keep so care with installing it.
Posted on Nov 25, 2009
Turn off power and reinstall the jumper in normal mode position) what can be done?
turn off the power
unplug the Power cable from CPU
see the manual of the motherboard or search out "CMOS Jumper clips" these are 3 pins in which 2 are covered with a small clip (called JUMPER), (most probably this is placed near battery) remove them and change the position, eg if the same are in position of 2+3 then move them to 1+2 or vice versa.
Now power on.
vote me if found helpful.
Aug 05, 2011 | Intel D945GCCR Motherboard
When i start my computer boot screen appears every time.
may be you cmos battery is weak just remove the battery and install new battery and also make sure jumper position is proper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Intel D945GCCR Motherboard
i get jumper the error massage is " Turn off power and reinstall the jumper in normal mode position
Sep 10, 2009 | Intel D945GCCR Motherboard
Turn off power and reinstall the jumper in normal mode position in intal(lga775)
if this message is appearing on your screen then the bios jumper is installed at reset position. so please install this bios jumper of your motherboard and the pin number 1-2 position of bios.
it will be allright
Apr 19, 2009 | Intel Biostar P4M800-M7A Socket LGA 775...
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time.
If this is correct, it is telling you that there is a jumper on the motherboard (probably labeled "clear CMOS) and it's set in the incorrect position. There will be three pins. The jumper is installed across two of them. Move the jumper (the little plastic thing) to the other setting: for example, if it's installed on pins 1 and 2, move it to 2 and 3. Give that a try. Will probably work for you.
Feb 11, 2009 | Intel D945GCCR Motherboard
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
Nov 20, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
189 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
