Question about Garmin StreetPilot c510 Deluxe GPS Receiver
Have looked at some of answers to streetpilotc510 problems, so can someone explain what loads to device and what loads to sd card. Other than deleting languages from device what else can I delete?
    Problem Solver:
  • 10 Answers
You can also safely delete vehicles to free up space (approx. 1MB for some of the more detailed vehicles)
Posted on Jan 03, 2010
Testimonial: "when I deleted all the unnecessary stuff could load everything thanks.Maps are laid out differently - nth,sth ireland and dublin, check uk for similar"
My Acer 3692WLMi does not read my Fuji 8 gig SDHC card but it will read my Panasonic 2 gig SD card. Can someone give me an answer/solution. Thanks C
While I'm not directly familiar with this Acer model, it looks to be an older laptop. It's almost certain that it was built prior to the SDHC cards being created - a lot of older memory card readers are not able to read the High Capacity (HC) flash cards. I actually own a couple of devices that also would not read the 8GB card.
To test, I would recommend finding a newer USB SD card reader that you could either borrow or purchase (they're usually not too expensive) to see if that reader could get the information from the SDHC card.
If that works, the problem would be that your flash card reader does not support the higher volume cards. This is the most likely possibility.
If it doesn't work, there may be an actual problem with the SDHC card itself.
Hope this is helpful!
May 13, 2011 | Computers & Internet
Tip
SD Card Write Protect
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
on Nov 29, 2010 | Cameras
I have a 26-IN-1 USB 2.0 Memory Card Reader device from DZ Tech (DigiZone Technology) I asked if there is a instruction manual for supported format applications CF ll, Microdrive, CompactFlash 1, Memory...
Look....what's so difficult about plugging a card into a card reader and then the USB into your computer? There's no instruction manual because that's all there is to it....why waste paper to explain that?typrice_150.jpg
Mar 09, 2011 | Cameras
Not enough space on device to put download into memory.
i had the same problem with a go 750 eventually i just bought a 4gig card and that solved the problem... you see a 2gig card isn't 2000mb it is only around 1900mb. i think that might solve your problem
Apr 29, 2010 | Tomtom GO 720 GPS Receiver
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it, but it says CHECK SD CARD. I tried another 1GB memory card and it worked. I know that the problem is with my...
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Mar 23, 2010 | Samsung Digimax D53 Digital Camera
My tomtom 1 xl is giving me a memory card symbol on the screen with a red cross over it !
do you have an sd card loaded?
if so and it hasnt been formatted for the tom tom then this can cause your issue, also if there has been an sd card in the device and then removed unexpectedly you will get the same issue.
hopefully this answers your query if so please rate my answer accordingly.
Thanks
Sep 14, 2009 | Tomtom One XL GPS Receiver
Serial number on memory card of TomTom??
Yes it does. Insert the card into a card reader or if you have access to the unit connect it to your computer. Open my computer and open the drive letter of the device. After you have opened the drive look for a ttgo.bif or ttgo.bak file open the file using notepad and it will tell you the device serial number and device unique id. I will tell you this though if their device is working and is not freezing at start up they are not using your sd card. Each sd card has a unique number and will only work with that device.
Hope this answers your question.
May 09, 2009 | Tomtom ONE GPS Receiver
What is sd card slot used for?
The sd card slot is used when you buy update maps.
It's easier to update directly from the website, but if for some reason you can't, you can buy the maps on a sd card or on a CD. Then transfer to the sd card and load it.
Dec 27, 2008 | Garmin nuvi 260W GPS Receiver
Where does the SD card go
Its on the side , take a look at this screen shot, it will help ya good luck!0aa1bd5.jpg
Dec 16, 2007 | Canon PowerShot A75 Digital Camera
SD card problem
The most likely cause for the RED CROSS is that some files are missing or corrupted on the SD card. This can also occur if someone has accidently dragged and dropped files on the SD card. ie. if a folder or file has been accidently dropped into a different folder. For instance you could drag and drop the maps folder into the voices folder. In this case the unit wouldn't load up if you had no maps although the maps would still be on the SD card but would be in the wrong place. We all know that files on media can be damaged or become corrupted so its always worth making a GOOD BACKUP of any sd card so that should this problem arise you can reinstall the backup.
If you have no luck with your SD card , you could try borrowing a card off someone you know and make a copy of it then activate that copy by using the original activation code together with the device code. .... good luck .
Nov 06, 2007 | Tomtom 1D00.081 GPS Receiver
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
169 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
