Question about Indesit WA 115 Front Load Washer
Indesit WIA 101 washing machine can be reset to left in the rinse program. if you sit on the reset button programs the LED remains lit and the rinsing of the door as
  • 1294 Answers
SOURCE: INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Posted on Jun 05, 2008
kjmac
  • 97 Answers
SOURCE: indesit wia 121 door lock
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Posted on Jul 28, 2008
SOURCE: indesit WIA 101
to open do power off after 5 min open the door with power off
Posted on Jan 13, 2009
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
miket756
  • 2702 Answers
SOURCE: indesit w93 is not rinsing,
this is most likley to be the programer brain its gone fulty on you,, its not a cheep part to get fixed sorry
Posted on Oct 26, 2009
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
I have an Indesit W1A111 and it spins, drains, rinses etc. It does everything it should do but if you put it on a programmed cycle it wont go pass the wash. For example if I put it on number 4 and press...
The normal procedure to reset the program of Indesit and like machines is to hold the start button for a a period of time in an attempt to reset the logic/programing. If unsuccessful, unplug the machine for a period of 5 to 10 minutes reset the selector to the desired program and hold the start button in hopes of clearing the memory of any previous commands. If this does not cure the problem the most probable causes are:
one or more of the 6 to 12 sensors (varies according to model and year of manufacture), around the drum, water drain pump, humidity sensor,ect.,has developed high resistance/corrosion contacts or due to vibration of wash and spin cycle, has shaken wire/contacts loose. If this is the case, remove the top cover plate for access. Clean and reseat the contact/connectors also check for wires loose in the connector, as they are simple compress crimps. The most probable suspect is visible on a duct, which is at top center over the drum. I would suggest that all receive service while you have the top off to avoid do it again in the near future. If this fails to clear the problem it is most likely a failed module requiring identification of the failed module and replacement.
sincerely Doc Michael
Mar 07, 2011 | Indesit W 123 Front Load Washer
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Indesit IWB 5123 Washer Which program ends with the washing left in the final rinse water until spin cycle is selected
push in yourrince hold/or crease gaurd button if you have one. normall wollen cycles will stop.
Feb 16, 2010 | Indesit W 123 Front Load Washer
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 101
Jul 27, 2008 | Indesit W 123 Front Load Washer
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
INDESIT WIA 101
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
1,236 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
