Question about Freezers
I have a Brandt Apollo frost free fridge freezer which is malfunctioning, it is about four years old. The fridge section is dead whilst he freezer funtions. I noticed also that the interior light had got very hot and distorted the surrounding plastic and had ceased to function. I do not know if the two are connected or whether the appliance is repairable. I have defosted the freezer which made no difference.
  • 288 Answers
It may be repairable. setting the freezer aside for a moment, check to see if the fans come on when you first plug it in. make sure the vents dont have food debris in front of them. If the fans do not come on, you may be able to simply replace the fan or fans that pull warm air and blow cool air into the fridge. they get there cooling from the same coils and the freezer is working, so must be fans or fan relay
Posted on Nov 27, 2009
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Hii have an indeset fridge freezer 2 year old freezer ok fridge not cooling
Usual problem, let it defrost properly, I mean 48 hours with doors open in warm room. It is most likely frozen up inside (its frost free! no?) inside is a different matter and they dont tell you that!
Mar 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Freezers Logo
680 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
