Question about Fuji FinePix F410 Digital Camera
Battery problem? the battery died and would not charge, we bought a new battery and that still didnot work, do you think the camera is broke?
5 Suggested Answers
SOURCE: Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Posted on Jan 26, 2007
sapir
  • 100 Answers
SOURCE: it wont work!
if it said fully charge its probably not yet.
could it be that you damage your camera in the first time that it was jammed?
Posted on Jun 22, 2008
SOURCE: Finepix f10 problem
Try holding in the power button on the camera with the charger connected to the camera & still plugged into the wall outlet. This may be a reset the manual doesn't tell you about or simply a weird fix for the same problem I had with my F10.
Posted on Jan 05, 2009
Rider On Way
  • 1679 Answers
SOURCE: My camera died whilst in the middle of taking a
Hi Tracy,
It definitely seems to be hardware issue, however you can still give it a try and it should work fine.
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please pleasefirst contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Suhail
Posted on Nov 03, 2011
My Coolpix s6000 just won't charge I bought a new battery and it worked for a short time and now as soon as you take it off the charger it dies. please tell me what I need to do to fix it or how to send it...
It sounds like one of two things. Either there is a short circuit in your camera that is draining the battery or the camera's battery charger circuit is not charging the battery. There are a few things you can do. You can send the camera to Nikon USA for repair (look on the Nikon website for the address the closest repair center). The other thing you could do is buy an inexpensive external charger for the battery and see if the camera works for a resonable period after charging the batteries externally. Adorama.com carries both the Nikon and off brand models and will give you the best price. It that works, you know that the camera's battery charging circuit is the problem. If that is the case, you could pass on repairing the camera and just use the external charger. If that does not solve the problem, the camera will need to be repaired.
Sep 07, 2013 | Nikon COOLPIX S6000 Digital Camera
Casio digital camera EX Z40 will not charge (on the cradle) I bought a new battery, thought the old one had 'died' completely. so now I think the problem is with the charger. The USB light functions,...
If the usb light functions, the problem is with the camera. Because it accept the charge but cannot deliver it to the battery. I think the problem is with the charging circuit, because it is in the camera, not the charger.
Feb 28, 2011 | Casio Exilim EX-Z40 Digital Camera
I bought a new battery because the camera wouldn't stay charged. It still does not stay charged for very long, only about 30 pictures and then it dies. what can i do to fix this problem?
I have the same problem with the camera not staying charged and no one can answer why. My battery is new and was $35 and I probably did not need it...
Oct 28, 2010 | Kodak Easyshare M753 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
My FinePix J10 is not working even after changing the battery
Your son probly jamed it in there to hard then the spring mybe broke
Jan 30, 2009 | Fuji FinePix J10 Digital Camera
It wont work!
Jun 22, 2008 | Fuji FinePix Z100fd Digital Camera
Just Stopped working...
I have the same problem, bought this camera in probally '05-'06 and sometime in '08 it just stopped working, just recently ordered new battery and charging accessories because the battery would even charge or light up the camera's charge button. Well it's not the batteries or any charging accessories, Its The Camera, anyone else know what has happend here? I bought When it first came out @ over $700 it seemed to be worth it till it died for no reason!!
Jan 22, 2008 | Sony DCR-PC55 Mini DV Digital Camcorder
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Open Questions:
See all Fuji FinePix F410 Digital Camera Questions
Fuji FinePix F410 Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
