Question about Bosch 24 in. SHU43 Built-in Dishwasher
Adjusting door spring tension on a Bosch dishwasher
We have a Bosch dishwasher.I cannot workout how to adjust the door spring tension.HELP
Underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Posted on Dec 28, 2013
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
aborcass
  • 2651 Answers
SOURCE: Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Posted on Oct 26, 2008
  • 209 Answers
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
Jus ask me
  • 120 Answers
SOURCE: BOSCH DISHWASHER SHV55MO3GB 60CM HOW DO
do you want to adjust the door spring or the door latch?
if the spring is damaged or misplaced you will have to open it and change it
Posted on Aug 03, 2008
  • 457 Answers
SOURCE: how do i adjust the tension of the door hinges on
you cant you only can change the springs. probably one is broken
Posted on Feb 25, 2010
How do I adjust the door tension on a Bosch SHU 6802 undercounter dishwasher to keep it from falling open
you cant change the tension more likely one of the ropes attached to door spring has snapped so you are only getting counterbalance from one spring not two.
Feb 04, 2017 | Bosch Dishwashers
BOSCH DISHWASHER SHV55MO3GB 60CM HOW DO I ADJUST THE DOOR SPRING ON THE MACHINE? AT PRESENT WILL NOT LIE OPEN AND SPRINGS SHUT WHILST TRYING TO UNLOAD.
Aug 03, 2008 | Dishwashers
Door lift spring came off how to put it back on
the spring will be at the lowest tension when the door is in the raised position
there should be an adjustment at one end where the spring is attached to adjust the ease to lift the door and hold it open so if thee is loosen that adjustment off and with the door held up ,refit the spring
Oct 22, 2015 | Hobart Used AM14 Pass Thru Commercial...
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
How do i adjust the tension of the door hinges on a bosch dishwasher?
Feb 24, 2010 | Dishwashers
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Door Tension
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dsihwasher Door adjustment
Turn the spring tension screw anti clockwise to reduce the spring strength Regards Engineer
Jul 27, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
3,521 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
