Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
I think i can smell gas from my fridge? - Bosch Classixx WVF 2402 Front Load Washer/Dryer
  • Bosch Master
  • 3,463 Answers
I doubt you can smell gas, as all refigerant gases are odourless, probably something else.
Please rate my comments.
Thanks.
Posted on Nov 25, 2009
Hi, we have a caravan which has an electrolux RM360 gas/electric fridge installed. There is a very weird smell coming out when the fridge is turned on. Its like an ammonia smell it is really strong,
Travel refrigerators use an ammonia coolant instead of freon. So the smell is telling you that you have a leak in the sealed system.
Suggest you look for a replacement fridge OR a rebuilt unit because that is usually cheaper than taking it to a service center for repairs.
Jan 25, 2012 | Electrolux Refrigerators
Smell of gas and fridge not working
If you are sure about the gas smell, it is due to a gas leak. It needs repairs. Take it to a repair center.
Oct 06, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Funny smell coming from under my whirlpool, side by side fridge freezer. I've often noticed this smell in shops with freezer sections. The only thing I can liken it to is stale ****!! Sorry!!
the smell is urea,it is the gas they use to make the injection mouldings (plastic and foam) it is HARMLESS,but does smell like **** cos its the same gas.........(the best leather is processed with femail ****.)use male **** to accelerate your compost heap... if you think im joking try it.....
Sep 07, 2010 | Refrigerators
Phillips whirlpool built in fridge /freezer smell coming from the fridge section,we have tried various things but the smell still persists
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Aug 30, 2010 | Whirlpool Refrigerators
Whenever I turn on my fridge it sounds like it is releasing gas and there is a funky smell in the fridge. I think it may be leaking some chemical but I cannot find the source of the leak anywhere.
If you have noticed this leak then this will be best seen when it starts cold. So shut it down and after removing all food from inside , restart and feel/listen/smell for the leak.
If you notice this slight smell coming from the cooling coils inthe freezer section, then do not waste time but shut it down.
You will need to remoe gas off by pumping , then the system be pressurised and checked for leak.
Get help with the equipments to check /estimate/confirm forr you to decide.
But always try to get a warranty on work if there is high estimate but decide with the cost of a new one. j
Aug 27, 2010 | Haier HSE04WNA Compact Refrigerator
When on gas smells of exhaust fumes in van and
sounds like the burners need a good scrub to clear carbon off jets.
May 07, 2010 | Thetford Norcold DE0051 Refrigerator
Fridge & Freezer smell like a gas grille...
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Jul 30, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Feb 04, 2008 | Maytag MBB1956GES Bottom Freezer...
Odours from fridge
frigidare makes a product called fridge- aid you can get it at lowes or any appliances parts store its made of activated coconut charcole it might solve you promblem
Jan 08, 2008 | Frigidaire FRS26R4A Side by Side...
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
99 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
