Question about Hotpoint TDC32 Electric Dryer
Ive got a hotpoint tdc62 dryer and have changed the belt on it. it worked for a few seconds and now nothing any ideas?
  • dwarfers75 Nov 18, 2009
    theres no noise at all, have tested the switch and the fuse and there ok. nothing happens at all when i press the start switch.
  • Andy Thomas
    Andy Thomas May 11, 2010
    When you say "nothing" Is there any sound at all from it? Regards aardvark repairs
    Scholar:
  • 62 Answers
If it was working ok before you changed the belt then i suspect a wire has come off somewhere. re trace the work you did and you hopefully will find the problem
Posted on Nov 18, 2009
I have a hotpoint tdc62 when on it works fine apart from a grinding noise when the drum is going round could it be the belt? its 5 years old never been changed many thanks
More than likely worn rear drum bearing or worn front bearings.
Remove the rear panel, and you should see the drum shaft, check for wear here.
Jan 15, 2010 | Hotpoint TDC32 Electric Dryer
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint condencer dryer TDC62
Several reasons for it not to heat.
Obviously faulty heater, and or thermostat(s). You need meter to test. Heater and stats are located at the rear of the m/c behind a removable panel.
Faulty programmer, faulty heater relay.
Check filters etc, refer to instructions for this.
Plz leave feed back on this .
Thanks.
Dec 12, 2008 | Dryers
I have just replaced a broken heating element on a Hotpoint TDC62, put all the covers back on, and tried to switch it on - but it won't work. I've changed the fuse in the plug, but still nothing. I have a...
There is no circuit breaker in this dryer as such.
Establish that you have got power to the m/c, if you have, then could be faulty door switch, or you may have inadvertantly pulled a wire off somswhere.
Try the dryer in another socket and make sure you know that the fuse is a good one.
Dec 10, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62
your dryer is probably worn out in the area of the front slide assy / bearing. They all do it. the drum is binding and stopping the motor sometimes...can be noisy too...
Oct 15, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
your thermostats have most likely gone they are situated at the back of the machine on top of the heater
Feb 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
153 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
