Question about HP DeskJet F380 All-In-One Printer
When trying to print it says door open, put it does not look open.
    Problem Solver:
  • 12 Answers
Check the door sensor when you close the lid,it may be worth cleaning the sensor with a cotton bud,hope this helps
Posted on Nov 18, 2009
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 15, 2010 | Office Equipment & Supplies
My printer has always worked fine and this time I went to get a new ink cartrige and I put it in and now it won't print. It printed one paper telling me how to print but other then that it is telling me...
I think it means the ink may not be seated properly, take the inks out again ( making sure the tabs have been removed ) and the refit them . If your still no better, write back and we can try something else
Aug 20, 2010 | Office Equipment & Supplies
I try to print a card or bank statements and nothing is printing just put in new ink, it only prints the 1st page of a quarter fold card, it should all be on one page and it prints only partial card
IF the Kodak AiO printer is printing partial ther are two main device of the printer that have issue on the scanner [where you put the document for copying] or the printhead of the printer.
Step that you can do
1. Try to print a test page in this way you can check if the printer prints whole page. How to print test page press copy button and photo button on the printer for atleast 10 sec. or until the printer starts printing. Reminder Test page doesn't need a document on the scanner glass. It will print an advertising doc for the printer. Now if the test page is half/partial it is the printhead that has an issue. If it print the whole page it is the scanner that has issue contact kodak for printer repair
2.Clean the printhead twice and reseat the printhead it
How: press menu button then select clean printhead then select basic/deep clean. To reseat printhead open the printer access door; remove the ink cartridges; remove the printhead; close the printer access door then open the printer access door insert the printhead then the ink cartridges.
3. Try to print again [For futher support call Kodak support line at 1 800 421 6699]
Nov 21, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer won't print - says door is closed, even when it's open
your door open sensor is not working proper.pls close this cover tightly..
Aug 16, 2009 | Office Equipment & Supplies
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I am having HP Deskjet 3920 Printer. When i try to print any documents, it will show an error message that " The Triclor cartridge is incorrectly installed" , although still it will print color prints...
Hi Anish, Have u checked the printer cartridges installed properly(i.e., Color in color door and black in black door). and also check the cabling between the system and your printer. and put the papers properly. if the problem again persists uninstall the printer driver and install the latest drives which can be downloaded from the net.
Thanks,
Sriram.S
Chennai.
May 02, 2009 | HP DeskJet 3940 InkJet Photo Printer
Not printing microsoft office documents, VIsta Software
Try to press the photo and copy at the same time it will print a diagnostic page
look how is the quality of the text.
if it prints very light or if it doesnt print open the access door and try to remove the ink cartridges and put it back again and make sure you hear a click sound after you put the cartridges back in and close the printer access door
try to print again a demo page press photo and copy and check if there is improvement
if no improvement open the kodak aio home center software click on the question mark(?) on the upper right corner and click on maintenance..then select printhead cleaning.After the printhead cleaning print again demo page (press photo and copy at the same time) if still no improvement on the quality of the text call the kodak hotline 1 800 421 6699..you might need a printhead replacement..
Nov 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Only prints in pink
Needs a New logic board which are nbot available
Apr 28, 2008 | HP PhotoSmart C4280 Laser Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
HP DeskJet F380 All-In-One Printer Logo
442 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
