Question about Lexmark C510 Laser Printer
Horizontal lines down left margin
Hi. My Lexmark C510 always produces horizontal lines down the left margin of each page. Looking at the "drum" (not sure of exact name, but it's the part right behind the 4 toner cartridges) I can see the impressions of these lines all the way down the left side. So it looks to me like that part needs to be replaced. I don't know why this occurred, or exactly how to fix it. Any help would be appreciated. Thanks.
  • mbondi Jan 10, 2008
    Thanks for the quick response. I realized that the part I'm referring to is called the photodeveloper cartridge.
    I know this is the source of the problem for two reasons: 1) when I look at the part of this cartridge that produces the image, it clearly has marks down the side corresponding to the lines. These lines show up in both colour and black, depending on what is being printed. 2) today, when I replaced the black toner, another line started to show up down the page about 1/4 of the way from the right margin. This was a different type of line, and I'm not sure where it came from, but it was also showing up on the photodeveloper cartridge as well. I used a soft cloth to wipe some toner debris from the cartridge, and the line disappeared.
    There is a lot of excess / loose toner inside the printer (not sure why but it is leaking from the black cartridge). This makes me concerned that it is the cause of the problem, and that a good cleaning of the printer may be required, in addition to the replacement of the photodeveloper cartridge (not a cheap investment, either). At this point, I don't know whether it is worth fixing, because I only paid $400 for the printer, and the photodeveloper itself is about $250. It may be worthwhile to simply replace the whole printer.
    Anyway, if you can add anything further, I would appreciate it.
  • 788 Answers
Sounds like it's a transfer belt and not a drum you are refering too. Each toner cartridge mose likely has a drum built into it. If the lines are only in one color it may be that toner that is bad. But most likely it's the transfer belt, often called an ITU (Image Transfer Unit) or ETB (Electrostatic Transfer Belt). They sometimes get contaminated with dust, oils from fingers, etc... and can't be cleaned, would need to be replaced.
Posted on Jan 10, 2008
  • Dean Joly
    Dean Joly Jan 10, 2008
    I've seen cartridges go bad and leak a lot of toner all over the place, can cause quite a mess. You can clean it, I use a clean paint brush to loosen the dust and toner inside the printer and then tack cloth or a lightly dampened lint free cloth to wipe up the toner. Make sure you don't touch anything as the oils on your fingers can also cause problems.
    You can attempt to wipe the photodeveloper with some 99% alcohol but I would avoid it or keep it as a last ditch effort but I haven't had much success doing it in the past.
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
My lexmark e120 printer prints with horizontal lines across the pages, how do I get rid of this?
Many times horizontal lines -- esp if constant (e.g. 4 inches apart) appear-- on laser printers indicates a drum issue. NOT usually inexpensive. Sometimes one can dis-assemble part of printer and clean drum with soft cloth and therefore "buy some time"
Sep 14, 2010 | Lexmark E120 Laser Printer
How do you clean the drum on a Lexmark C510 printer. One of the suggestions for the horizontal colored lines suggested this. I don't see such instructions in the manual. Thanks
DON'T clean the drum. You'll demage it. Try to find out witch color the line is and replace the cartridge. Mostly this solves the problem. If more colors, than more cartridges to replace.
Jul 19, 2010 | Lexmark C510 Laser Printer
How to clean Lexmark Z1320 printer.
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Lexmark T614 horizontal lines on right the left margins
This sounds like a cartridge problem if you have changed the cartridge and the problem persists I would say it is the positive charge roller inside the printer. If you open the cartridge door and remove the cartridge with the cartridge out starting closing the door and you will see this roller moving down from the top inside of the printer. do not touch this without a glove or lint free cloth. not hard job to change if you can get one in your area if not we have them available.
Feb 05, 2009 | Lexmark Optra T614 Laser Printer
Horizontal line from the feeder when making copy
your printer recycler is full from ink and may streteches on your drum
Feb 06, 2008 | Lexmark C510 Laser Printer
Lexmark C510
try to clean the toner from tissue paper or if you want good quality you replace the toner or copen the cover of printer toner and clean is there any ink powder is there. bye
Sep 21, 2007 | Lexmark C510 Laser Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark C510 Laser Printer Logo
679 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
