Question about Hotpoint First Edition FEW12 Front Load Washer
Where is the filter on Hotpoint first edition washing machine ?
    Scholar:
  • 62 Answers
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Posted on Nov 18, 2009
IFIXALL
  • 868 Answers
SOURCE: Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
Posted on May 26, 2008
  • 1462 Answers
SOURCE: filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Posted on Jun 29, 2008
  • 5 Answers
SOURCE: how to change drum bearings
Right - all washing machines are pretty similar except between manufacturers such as Dyson, who use such things as three seperate drums.
The average washing machine is simply a motor attached by a belt to a drum, with a programming unit that connects to a door sensor and heating element, and a seal that goes around the drum.
Since we are dealing with Hotpoint, the first thing to do is take off all panels from the front, the top, and the back.
From the front: You will be able to see your drum, and should be able to undo the seal. Basically at this point, unscrew everything attached to whatever I describe - remembering where they go. Now the front seal is sometimes attached to the case that surrounds the drum - usually with a heating element attached to it on some models.
From the back: You will see the belt attached to a flywheel that turns the drum. Rotate the drum to check that the rumbling / banging noise is still occurring. Check that the drive belt isn't damaged or worn as this can cause problems. Unscrew the huge bolt that holds the flywheel on to the drum (rotate anti-clockwise). This will usually take a lot of force and is better to use a large spanner, lock it in place, and turn the actual drum with your hands if you can't undo it. Now when this comes off, you will be able to pull the drum free. Move it around until it comes away. The bearings may drop off the drum's shaft so retrieve them. Check to see if they fall apart as this indicates the bearing's seal has gone totally. This is the part to replace. Buy a replacement the exact same size for your model of washing machine and reassemble - ensuring that all screws go back in the right place.
Hope this helps. Remember that it is just a case of unscrewing things in the right order. You learn best by just doing - so if you are mechanically minded - this sort of thing will be a doddle. If you get stuck and can't remember how to reassemble it - call out a repair man and watch how he fixes it as this will of course allow you to try it if it goes bad again ( a common problem I've been told with Hotpoint and Zanussi models since they are manufactured using cheaper parts than others. )
Posted on Nov 09, 2009
barkencoa
  • 3463 Answers
SOURCE: my machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Posted on Jan 02, 2010
  • 662 Answers
SOURCE: hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
I cant find the filter on the hotpoint first edition wma 20
i had this trouble for ages, u have to tip it on its side or bck as the filter is up underneath
Sep 29, 2011 | Hotpoint First Edition WMA20 Front Load...
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
Jan 13, 2011 | Hotpoint First Edition WMA12 Front Load...
Our Hotpoint WMA20 Washing machine is not draining, even though it appears to do a fast spin. The machine was installed several years ago and has previously worked normally. Is there likely to be a...
Filter is tbe found by removing lower rear cover of washer, and removing the large black hose fastened to bottom of drum, remove and clean plastic filter inside the hose.
Aug 24, 2010 | Hotpoint First Edition WMA20 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
My machine won't drain and I can't find the
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Cant find my filter o a hotpoint first edition
i cant find the filter on my aquarius either, but i just read somewhere that this egg smell is probably caused by u mostly running the machine on cool washes i.e 40' ? so its suggests u run the machine on a 95' empty wash using ure normal detergent 2-3 times a year as the smell is a build up of bacteria because your washes arent hot enuff to kill it. If ure egg smell is bad, i'd do the empty hot wash thing a couple of times to make sure ! hope this makes sense?! :)
Apr 30, 2008 | Washing Machines
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
1,617 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
