How do i replace the inducer motor myself?? Is it hard or dangerous??? the technichian said i need a new draft inducer motor. I was wondering if it was hard to replace it myself, and if someone can give me instructions on how to do it.
  • 614 Answers
Most draft motors are easy toreplace but get the intire draft assembly. Most of the time you damage the blower wheel getting it off. Let me know rus
Posted on Nov 18, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Tip
Draft Inducer Motor runs continuously and the furnace does not heat
If the Gas Furnace's Draft Inducer Motor runs continuously and the furnace is not heating, it is most likely "locked out" as a result of a safety device sensing a dangerous or out of ordinary condition. There are a few things you can check. Here is a video explaining how a gas furnace works and demonstrating how to identify some of the most common safety devices that you should check.
Here is a video that contains information on another common failure, how to identify it, and what to do.
on Mar 20, 2010 | Heating & Cooling
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
York diamond 80. when power is on should the red indicator light on printed circuit board be on. Replace flame senser furnace main burner still shuts down after a few seconds and we get 5 flashes from
Check polarity to the furnace, it must be correct, not likely unless new or worked on though. The induced draft has a pressure switch that has a tube that connects to the induced draft housing, that orifice clogs with carbon and a tiny drill bit is used to **** the orifice clean, it will be hard if pluged, you know you are clear when you fel,hear the inducers squirrel cage with the drill bit, the tubing if dipped can collect condensate and block the pressure of the draft to be sensed by the pressure switch and the pressure switch can be bad or off too. If the flue is blocked or induced draft wheels burned up/rusted out, not much draft is induced, you need to snoop a bit.
Oct 30, 2012 | Heating & Cooling
I have a goodman model#GMH80703ANAA SERIAL#0607148632 -I HAVE NO MANUAL AND WAS WONDERING WHAT THE LOW FIRE ON GAS VALVE IWC SUPPOST TO BE SET AT. AND WHAT THE HIGH FIRE IWC PRESSURE SHOULD BE SET TO.I do...
I have done this 34 years and never need to know this . simply replace the $15 part to see if it works, labors not cheap and its better value to the customer for you to sawp it out on a call even if its not bad yet as they are 1 of the weak links that you know will fail . if it doesnt work, which i never saw except when the orifice on the induced draft housing was carboned up! or 1 time the induced draft squirrel cage was disintegrated with the motors shaft left spinning nothing and doing nothing as toinducing any draft! threw mw as the motor was working! and orifice clear and new switch but still not working!!! had to be the cage or poltergeist lol!
Feb 24, 2012 | Goodman Heating & Cooling
I removed my Fasco 7021-11577S when the bearings went bad and ordered the A225 OEM replacement. I notice that when mounted this new draft inducer it whistles really loud .Is the hole in the back of the...
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
Mar 29, 2011 | York Furnace Draft Inducer Blower Fasco #...
I have a Payne furnance, yesterday it stop giving up heat but give out only cold air. The led sensor light blinks 3 times slow pause in between and fast 3 times after. What do I need to fix this furnance...
Hello, it sounds like the pressure switch is not closing on your furnace and remaining open, reasons for this could be a blocked flue pipe, the tubing going from the inducer motor to pressure switch could be blocked, loose, or have condensation in it, or the switch itself is bad. U can check the tubing by taking it off blowing some air through it and making sure no condensation is in the tubing, then reinstall it. If everything checks out good then the pressure switch is bad and must be replaced.
Mar 02, 2011 | Heating & Cooling
I bought a new inducer motor and wondered if it matters which way you hook up the two wires on the motor because they are not labeled
Sorry this took so long...I just came across this post today...
No, it does not matter. Wire one line wire to one motor lead pairing either lead to either wire.
John
Nov 14, 2010 | Goodman B1859005 Induced Draft Blower...
Draft inducer runs continuously, unless i turn the furnace off at the fused switch on the furnace. Turning the Honeywell thermostat to the off position does nothing to stop it, nor does removing the front...
Sounds like some one needs a new induce draft fan relay, if relay is located on the main control board you have to replace control board,follow wires from inducer motor and you will find the relay. I could help you more if i knew model # and serial # of the furnace, Good luck.
Feb 06, 2010 | York Furnace Draft Inducer Blower Fasco #...
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
