Question about Bobrick B-2111 Classic??¢ Series Vertical Tank Soap Dispenser
Need the plastic refill window. - Bobrick B-2111 Classic??¢ Series Vertical Tank Soap Dispenser
You need to know if the B-2111 was manufactured before or after June of 1997
Before June of 97 part # = #2112-34
After June of 97 part # = #2112-38
You should be able to purchase each one for under $5.00 ShopBobrickdotCom
Posted on Dec 09, 2009
I have Printer refill powder in plastic bag, can i use it to refill some printers catridges or i need machine to make refill ink?
whats the model no of the machine? ink and toner are 2 totally diffrent things one is a powder and other is a liquid
Sep 25, 2013 | Konica Minolta 8936-488 Developer Model...
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    Change refill in a franklin covey bristol mini pen
    Hello, I have a Franklin & Covey Lexington ballpoint which looks similar to yours. To replace the refill pull apart the outer top and bottom sections, grip the plastic top of the refill and unscrew anti clockwise. Remove refill, replace and screw in new refill clockwise (but not too tight). Hope this helps.
    May 30, 2012 | Franklin Covey and Bristol Mini Journal...
    Its a 96 jetta not 04, where would I put the tranny oil in it?
    The filler tube is located above the front of oil pan and has a plastic cap.Pry the plastic cap off ,remove plug from the filler pipe. Refill 3.2 Qts., Full refill(dry) 5.9 Qts.
    Nov 07, 2009 | 2004 Volkswagen Jetta
    How to refill the cartridge of mfc 490-cw printer
    Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
    1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
    2. make a hole on the left side (NOT in the midle) and do it straight and don't go deep (see picture)
    3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
    4. put your plug, tape, hot glue or what ever you have to seal the hole.
    5. put the cartrigde back in your printer, do a print test and this is it.df2ceb6.jpgd909d62.jpg
    Oct 28, 2009 | Brother MFC 490cw Color Inkjet...
    How to refill brother LC65 ink cartridge I have the refill kit but no instructions
    Sep 13, 2009 | Office Equipment & Supplies
    How to refill brother lc61 ink cartridge
    2. make a hole on the left or right side (NOT in the midle) and do it straight and don't go deep (see picture)
    5. put the cartrigde back in your printer, do a print test and that's9d5859a.jpg8c316c6.jpg it !!!
    Jul 08, 2009 | Brother Office Equipment & Supplies
    I have a Brother MFC-240C printer and need to refill my yellow ink cartridge but don't know how to. I have misplaced the instructions that came with the refillable ink bottles. Can anyone help me.
    YOU are NOT SUPPOSED to "refill" the actual ink cartridges, but replace them with new ones. If you need to know how to replace this ink cartridge (I have this machine too) you just pop open the front rigth side panel and then pull the little plastic purple lever down in front of the YELLOW cartrdige which is labeled with a Y on the pull down cover in front of it, and pull out the old one to dispose of it, take the cap off the new one and push it in-the direction the arrow on the cartridge is facing until it clicks and the purple plastic piece locks it in, then shut the cover and the machine will do a "cleaning" and then you will be ready to print.
    Feb 22, 2009 | Brother MFC-3240C All-In-One InkJet...
    Brother laser cartridge refills
    OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
    Sep 20, 2007 | Brother MFC-7220 All-In-One Laser Printer
    Bobrick B-2111 Classic??¢ Series Vertical Tank Soap Dispenser Logo
    Top Bobrick Home Experts
    john h
    Tom Chichester
    Are you a Bobrick Home Expert? Answer questions, earn points and help others
