Question about Refrigerators
Smeg FABS30 the fridge/ freezer and internal light have stopped working at the same time, i thought this would be power supply, i have checked plug, replaced fuse in plug, checked mains socket is working, checked where power lead attaches to fridge for loose connections but no joy does anyone have any suggestions ?
  • 770 Answers
You are correct in your assumption...it is the power supply, as long as the bulb is good. The bulb should get power when the door is open regarless of whether or not the fridge is cooling, indicating a power break somewhere. First, remove the bulb and try in a lamp. Next, assuming the bulb proves to be good, you will need to remove panels necessary to trace the wiring. I suggest the use of a tester to make sure that current is flowing thru the cord, then into the fridge. Follow the wiring and check at every connection. Also look for loose or corroded grounds. If you do not feel comfortable doing this, it will be necessary to have an appliance repair svc conduct the repair. Good Luck! I hope this is helpful!
Posted on Nov 18, 2009
Zanussi fridge freezer
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
I have a tall smeg fridge freezer. Freezer compartment working perfectly. Fridge not cooling despite all lights being on. I've switched it off then on, turned the thermostat down, then up again...
Hi Evelyn,
Has the freezer been defrosted lately? Perhaps a buildup of ice will not let the refrigerator cool sufficiently. Try this and let me know how it works out for you. If it does not have a self defrosting cycle on it, it may take some time, just do not use a sharp object in the freezer as this could puncture the freon lines and that would render the unit useless.
Joe
Sep 21, 2011 | Smeg Refrigerators
Smeg CR330SE fridge/freezer hi there fridge freezer has stopped cooling in both compartments. light still comes on in the fridge and the compresser at the back is very hot.... any ideas???
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Smeg CR330SE 1 Bottom Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Smeg Fab40 fan stopped working - there is a build up of ice at bottom right freezer.
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
Mar 31, 2010 | Smeg FAB40PS Top Freezer Refrigerator
Smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Jul 11, 2009 | Smeg FC40RX Bottom Freezer Refrigerator
Smeg fridge freezer
Just check the Defrost Timer and turn it to the Clockwise direction using a screwdriver, can help not sure
Apr 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
