Question about Kirby G5 Bagged Upright Vacuum
When the power assistance drive to my G5 is engaged it is fixed in reverse.
  • 36 Answers
I know the problem is not the tec-drive, it is the position on the handle piviot spring assy. no parts should be required to fix this issue. However a vacuum repair shop will be needed for this problem. I would find one that offers free estimates. might save ya some money.
Posted on Nov 20, 2009
  • Anje Yelf May 23, 2011
    What should be the correct position of the handle piviot assy? A diagram with labelling should answer this. Please supply information.
My Kirby G3. The power assist (DRIVE) takes off and does not allow the vaccuum to return. It has a very strong drive assist. How do I get it to reverse and not just drive?
I do not know much about Kirby G3. Did you read the instructions because sometimes we over look a part or we didn't understand the instructions and it might be a important part of the machine. Also it might be a faulty chip in the vacuum not telling it to drive instead of reverse.
Nov 01, 2016 | Kirby Vacuums
Kirby drive wont go in reverse.
The slide will need to be adjusted (may of come loose )
Aug 15, 2014 | Kirby G5 Bagged Upright Vacuum
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
Oct 10, 2009 | Kirby G5 Bagged Upright Vacuum
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
May 30, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
173 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
