Question about Electrical Supplies
Where do I fit an earthing spike and how..? - Electrical Supplies
  • 484 Answers
As close to the service entrance as possible. That is to say, where your exterior electric panel is. If the ground is soft enough, you can use a sledge hammer or single-jack (3lb/1.4kg hammer) and a ladder to pound it in. If the ground is hard, trickle water on the spot to use overnight to make it easier and get an electric demo hammer with a rod-driving bit to drive it in for you. You can rent these at larger home improvement stores. Make sure you have a friend or two to help as you will be up a ladder with a pretty heavy and ungainly tool for this job. Once the ground rod (earthing spike) is all but a few inches into the ground, use an approved rod clamp to bond your ground (earth) wire and then install in the panel.
i hope this helps,
matthew
Posted on Nov 20, 2009
I am fitting a hager ez003 timer to our board does it need an earth as when we took off the old timer there was an earth fitted we are fitting it through an hager es 420
Wiring diagram for EZ420 delay timer does not show ground or earth connection.
It shows 12-230 volt AC Hot and Neutral, or 12-48 volt DC +-.
I assume the body of the timer is plastic/ cannot be taken apart/ has recessed screws and terminals/ and is double-insulated? Making ground or earth unnecessary.
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/pdf/EZN003_delay-timer-User_Instruction.pdf
Gene
Water Heater Timers Save Money
Aug 04, 2015 | Hardware & Accessories
Why does my head lights keep blowing
lights blow because of several problems
excess voltage from a faulty regulator is a reason they blow
loose bulbs that cause voltage spikes will blow bulbs
loose /dirty earth terminals will also cause spikes
poor quality bulbs where the filament sits horizontal and not vertical that allows the filament to vibrate and collapse
The first test would be the voltage regulator to ensure that it does not go over 14.6 volts
May 03, 2015 | Motorcycles
Can someone tell me if a condenser in an ignition system needs to earthed please?
Yes it does. The condenser stores spikes of voltage to help make the points last longer.
Feb 20, 2015 | Cars & Trucks
Change battery cable
Hi there
ORDER 2 NEW CABLES both with new terms and lugs already fitted on to cables,then remove Pos + term first and then earth and then fit pos cable on the same way as removal ,and then fit the earth lead to engine then to battery..
Dont forget earth lead off first and on last (on battery)
Apr 21, 2014 | 2003 Chrysler PT Cruiser
Cobra 25 uk ltd when mic keys needle spikes
It is important to ground the antenna well,get an swr meter and check the swr it needs to be less than 1.5
Jun 13, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
My scion 2006 xb keeps having #3 coil pack failing 3 all together . It was once a year now its more.
high resistance can cause this ,, bad plugs ,, bad connections or bad earths all cause high resistannce which can cause a voltage spike in the system potentially damaging coils or even the engine ecu ,,,
Feb 11, 2012 | 2005 Scion xB
How do you fix a broken stop switch on a 455 rancher
The stop switch is just a red plastic rocker that connects the earth cut out wire from the ignition unit, to a grouding wire to cut the ignition,it can be changed on the machine, however it is much easier to remove the air filter housing, start by removing the screws, two at the top and two at the bottom, disconnect the earth wire and the earth return wire, the upper wire has a spade conection onto the earthing strip, the lower wire also has a spade conection but just pushes into the red ignition rocker switch,unhook the choke from the carb, once the housing is removed gently pry out the blue choke pull from the housing, once removed pry off the broken rocker switch, this is sprung loaded via the earthing strip, pay close attention to how this is fitted, so as you know where to re fit if ( take a photo with a mobile phone to help with re instalation )now fit the new rocker switch, re install the earthing strip, re fit the choke pull, re assemble the air filter housing onto the back of the carb, re connect the wires.
Feb 26, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do i ground my antenna base or mobile ?
If you're using it in a car the antenna makes contact with the body of the car either through the magnetic base, if you're using one, or the metal clip if that's how you attached the antenna to the car. Either way the contact between the antenna and the body of the car acts as a ground.
If you're using it in your house it depends on the type of antenna you're using. Home base antennas have spikes that stick out from the base of the antenna. These act as a ground. If you're using a mobile antenna in your house, which will not give you a great signal, you need to connect it to something metal. Linking the body of the transceiver to the copper piping of your central heating or water heating system provides a good ground for the radio. As the ground of the antenna is connected to the metal of the transceiver body this is the same as grounding the antenna. Even if you're using a proper homebase antenna it's still a good idea to earth the radio as it improves the signal and reduces noise interference
If you're using the CB on a ground floor you may be able to run an earth braid wire outside and put a metal spike in the ground and connect it with your earth braid. Connect the other end of the earth braid to the metal on the body of your radio. NOTE: When connecting an earth to the body of your radio it must not be a painted part of the radio. You could drill a small hole in the body if necessary and put a nut and bolt through it to connect to the earth wire.
I hope this answers your question.
Jan 08, 2011 | Cobra 19 DX IV CB Radio
Hi, I have only used my CA 740C a few times and the fuse blows, I placed another fuse in and that blew as well. Haven't a clue why this might be happening can you help please? Thanks
Looks like a electrical problem. Ensure your plug's earth is properly connected to the building earth. Amps like 640A uses sensitive circuits and the fuse will definitely blow, when there are issues, spikes or returns in the power supply.
Try shifting the amp to a different wall plug with some proper ground earth, and check it. If the fuse still blows, then the power cable in the amp may have some problems.
Hope this helps :-)
Jan 04, 2011 | Cambridge Audio Azur 640A Amplifier
Screen shaking and pink and green line on botom
There is problem is with your LCD. I have already faced this thing earlier.
What actually happens is when you start your computer the liquid crystals on the screen get excited. In some faulty instances of liquid crystal configuration, this problem is existent. May be this is arising due to spikes in your electrical connection or due to improper earthing.
First, check the earthing for proper ground. You may use extensions with spike manager. Also, if your laptop is in warranty, you can get the LCD replaced for free because I suspect that you have purchased it recently and this is a manufacturing defect.
Please do write to us, we are following up to provide you the best assistance.
Regards.
Jul 21, 2010 | Microsoft Windows Vista Ultimate Edition
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
