Hi my battery is Fully Charged but When I Turn It On nithing Happens No Lioghts No noise No Nothing Any ideas
  • 497 Answers
1. Turn OFF the Computer and disconnect the AC Adapter from the Computer.
2. Remove the Battery from the Computer, clean the Battery contacts with the pencil eraser.
3. Insert the Battery in the Computer after 5-10 seconds and try turning ON the Computer with the Battery power only (without connecting the AC Adapter).
4. If the issue persists, remove the Battery, connect the Computer with the AC Adapter and then try turning ON the Computer using the AC Power only.
5. Remove the RAM Module from the Computer, clean it, insert the RAM in the Computer and then try turning ON the Computer (either with the AC Power only or with Battery only).
6. Try connecting the AC Adapter to different working Power outlet.
If the issue persists after performing all the steps as mentioned above then the Computer requires service.
Good Luck!!!!!!!!!!
Posted on Nov 18, 2009
    Sergeant:
  • 271 Answers
Your battery needs replaceing.
When i turn the key on the scooter, nothing happens and nothing lights up, i have checked connection and all show power, the power indicator does not move, yet batterys are fully charged any ideas TIA
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
Regards
Rob
Nov 05, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Mobility scooter
Check the inline fuses inside the tiller.
Dec 29, 2014 | Health & Beauty
My battery is fully charged all lights are working radio is playing and door chiming, but when I turn the key absolutely nothing happens. It done this two days ago and even though the battery was charged a...
Do the dash lights go out when you turn the key, If so then have the battery load tested, With a bad cell in the battery all lights and radio will work,( only a small draw on the battery) but when a heavy draw as in starter the battery will fail.
Oct 04, 2017 | 1987 Nissan Pickup
Ride on lawn mower wont start
Sounds like the starter or the starter solenoid is bad.
May 30, 2012 | Garden
My bmw 325 will not start battery is fine all dash lights are fine but nothing happens when i turn the key
Try changing your starter motor relay under the hood or its possible the starter has simply went out. if high mileage is present.
Apr 05, 2012 | 2003 BMW 325
Trying to fix my Volvo S60 2002 model. It won't start but when I hook the jumper cables to the my battery i have all interior power. when i try to turn over the engine nothing happens except clicking....
Make sure you have a fully charged battery...clean the terminals real well.
Alternator only charges the battery when the correct engine rpm is attained.
A clicking noise could be the starter solenoid which is basically a relay / contactor but can block power from reaching the starter.
Worn brushes in the starter can also zap a battery's power.
Battery, starter and aloternator can be tested at most part stores.
From what you describe, I'd clean battery terminals and ensure battery is fully charged.
If clicking still happens, I'd move to the solenoid and starter.
Hope this helps...
Aug 28, 2011 | 2001 Volvo S60
Mower sat over the winter. Turn key and nothing
Neither ... charge the battery first. New doesnt necessarily mean fully charged.
Charge it with a properly sized charger for 24 hours then check with a volt ohm meter.
May 01, 2010 | Garden
All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
79 people viewed this question
jasbo
jasbo
