Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Blue does not work properly after cleaning several times. Is there something else I can do. I have changed cartridges as well.
    President:
  • 787 Answers
Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If cyan ink cartridge is not OEM, try with OEM ink cartridge.
If this not help better think about new printer, because cost of repairing this one is profitable.
Posted on Nov 18, 2009
Testimonial: "Thank you so much. I went through the powerful cleaning once, did a print test and everything is working perfectly. Advice was received within 10 min"
Can install cartridge message mean current cartridge needs to be replaced?
This error means that the printer is not able to connect properly to the cartridge's chip!
Inspect the cartridge, every cartridge have a chip,
Clean it with isopropyl alcohol, or normal alcohol (But it needs more time to dry)
Clean the printer contacts that connects to the chip on the cartridge with isopropyl alcohol.
Reinsert the cartridge into the printer
and see if something change.
Is the problem still remain, probably the cartridge have a bad quality chip.
Jan 01, 2015 | Canon imageCLASS D320 All-In-One Laser...
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Why is my canon pixma mp 160 scanner not functioning?
I had my cartridge refilled and the blue had gotten in to the yell they cleaned it out all seemed fine now the pruner displaysE 1-4 the cartridge is the right one and worked yesterday, just needed to be filled, what can I do I tried pressing the reset button 4/5 times nothing is helping, re inserted the cartridge very frustrated have changed them several times no problems.
May 04, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Printed pages have blank lines in the print for the red, blue and yellow colors. Have tried cleaning and deep cleaning several times. No change.
If cartridge is good, prime and allign, remove cartridge and clean copper contacts with contact cleaner, if all fails replace printer.
Dec 17, 2009 | Canon MP610 Photo All-In-One Printer
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black won't print. Changed all ink cartridges,
It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
Jul 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Prints documents but there is a grey hue on all the pages
You might try changing the toner cartridge. While you have the toner drum cartridge out, clean the carona wire by moving the blue tab on the drum to the left and right several times. Be sure to store the tab all the way to the left before you reinsert the drum/toner cartridge assembly.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Drum ( i think)
I had the same problem and emailed brother. they suggested cleaning the drum by taking out the toner cartridge, and cleaning the primary corona wire which is inside the drum unit and can be found' by locating the blue tab on the top of the drum unit and sliding it from left to right several times. Return the blue tab to the home position before reinstalling the toner and drum unit assembly.'
The blue tab thingie is in the back and goes side to side which is different than the blue tab that you push to get the toner cartridge in. That one goes back and forth.
Anyway, I tried it and it worked for me.
P.S. the instructions from Brother also said that you might want to clean the laser glass with a dry lint free cloth. This is the think piece of glass above where drum unit is installed. they warn NOT to use any liquid. However, i did not have to do this. the blue tab (corona wire) worked by itself.
Apr 30, 2008 | Brother DCP-7020 All-In-One Laser Printer
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
107 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
