Question about Neff U1721 Double circotherm Electric Oven
Lower oven not giving out any heat, fan working, light working
  • Neff Master
  • 3,463 Answers
If fan is working ok, then you need to fit a new oven element, located at rear of oven behind a removeable cover.
Please rate my soution.
Thanks.
Posted on Nov 18, 2009
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
No heat from my oven Gaggenau EB 868_6
hi amy,
          it seems there is a defect in ur owen..because if light and fan works, it should heat, otherwise it means there is a fault in the heating element..so kindly cal any near by technician to sort out this problem or use our find oven repairman service to contact d near by repairman...
good luck
Jul 06, 2008 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Lower oven does not heat up the fan and light still work it is just under three years old what could be the problem the upper oven works fine. it is a whirlpool oven
If `the fan is working o/k, then you need to replace the oven element, located at rear of oven
Please rate my solution.
Thanks.
Aug 19, 2009 | Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Lower oven not working
Make sure the timer if it has one is set to manual and not auto. If it has a fan and it is running, then the oven element has gone. Replace.
Dec 14, 2008 | Ovens
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Neff U1721 Double circotherm Electric Oven Logo
191 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
