Question about Canon PIXMA iP90 Mobile Printer
I think I have to replace my ip90 printhead. The colors print fine but no black ink. I'v had it almost three years and I LOVE it, so want to try and fix it. I can order a new print head, but want to find out how hard it is to replace...anyone know? ...and is it just one printhead for black and color or do I order separate heads? THANKS for your help.
danasaur
  • 77 Answers
SOURCE: Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Posted on Dec 12, 2007
Soulvisitor
  • 1113 Answers
SOURCE: print head for canon ip90
yes
6d8b426.jpg http://www.softwareforless.com/findspecs.asp?partid=52912B
Posted on Dec 29, 2007
SOURCE: MP 360 won't print
the Cartridges is Jammed on my MP360 ImageGlass all - in one Printer
Please advise me how to fix it
Thanks
Yatiha Balfour
Posted on Feb 25, 2008
  • 105 Answers
SOURCE: Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
Posted on May 12, 2008
bob_computer
  • 3153 Answers
SOURCE: my canon inkjet ip90 error color ink not installed but it is
A few basic causes. Most of them generic but should be able to help you out
1. The cartridges you bought were not original equipment ones (OEM)and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printer through the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
%. The head maybe just plain old pooched (not always repairable but on occasion...)
If you are filling them yourself then...
Cartridge ink levels are usually monitored by a small chip on the cartridge. If that cartridge is allowed to fall below 25% ink level most chips then become locked and not able to re-set.
For many cartridges you can buy a reset device to reset chips that have not become locked. Or you could buy empty cartridges that don't need resetting and that will always accept a self refill.
As for scanning if by that you mean the photocopy function then that could be linked to any of the above. But should you mean it wont scan to the computer then you should look at any hardware or driver issues that you may have and maybe also the source selection (usually TWAIN) is a good source selection.
If this information was useful please click below
Posted on Aug 18, 2009
IP90- peformed all of the cleaning procedures
It may need a new printhead, QY6-0052-000, but there is also a firmware upgrade the shop has to do to help black cleaning.
Nov 25, 2009 | Canon PIXMA iP90 Mobile Printer
My Cannon iP90 has not been used for about a year. I replaced the ink cartridges, performed a partial and full clean. Printed text is barely readable -- to light printing in black or in color.
The ink dries in the printhead and you need to replace it, QY6-0052-000 runs around $60.00 now, leaving it set is the roughest on these printheads.
Nov 23, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 won't print black. Replaced ink, deep cleaned heads, etc. Will print color, but not black.
You probably need a new printhead, but there is also a new update for that machine to help clean the black part of the printhead. QY6-0052-000 is the printhead #
Sep 24, 2009 | Canon PIXMA iP90 InkJet Printer
Replaced black ink, now it only prints in color -
If cleaning doesn't help, you may need a shop, there's a firmware update that helps with black printhead cleaning, try a couple of deep cleans first, you can select just black deep cleaning.
Sep 10, 2009 | Canon PIXMA iP90 Mobile Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Canon iP90 Printer Problem
take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer
Jan 02, 2008 | Office Equipment & Supplies
Canon PIXMA iP90 Mobile Printer Logo
47 people viewed this question
old marine
old marine
