Question about Philips Irons
Lost the details on how to clean Philips GC2540 iron. Please can you provide some information.
    President:
  • 1,335 Answers
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Posted on Nov 18, 2009
Philips manual
You should clean your Philips Steam Iron. Follow the video guide given below to clean your iron
Aug 16, 2014 | Irons
Steam iron model 14884. Need replacement filter. Can I get locally or only order online
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide manufacturer name of your steam iron. Also which city are you located in.
Jul 31, 2014 | Irons
Iron not working
is there power to the recepticle which you are pluggin it into? Do you have power in the rest of the structure you are in?more details are better.. what have you done to explore the problem further? What happened the last time you used the iron - did it work ok then?
Best regards
Ck
Please provide feedback ratings
Oct 03, 2011 | Philips Irons
How do i clean my gc3531 iron
Hi e st clair...
I would use CLR to clean your iron.
Mix it according to the directions with distilled water.
Can be bought at Home Depot,Loews,Walgreens,CVS,Ace Hardware and many other places.
After cleaning rinse completely free of contaminated water with clean distilled water
Please take time to rate me
Sep 04, 2011 | Philips GC 3111 Iron
How do I clean the Baseplate
Good day!
The easiest way to clean the base plate of your electric iron is to use a sand paper (P200) p200 is the number of the sand paper that you need to use..
Scrub gently it in the base of iron until the real color of the metal is appear..If the color of the metal is appear it means the metal base plate is cleaned and ready to use..
Thank you and I hope this simple information help you..
Jun 17, 2011 | Philips Irons
Lost my self cleaning instructions, please help
You can download the complete instruction manual in PDF format by clicking this link.
The detailed steps for self-cleaning procedure is given on page 6 of this manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 15, 2010 | Rowenta Effective DX1900 Iron with Auto...
How do I cal clean my Phillips iron please
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Mar 21, 2010 | Philips HI-296 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
Help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
May 17, 2008 | Philips HI-296 Iron
Irons Logo
575 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
