Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Works for 10 minuets and stops
Works for 10 minets and stops .clean wash and dry filter .dry over night,still the same .
  • Dyson Master
  • 379 Answers
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor is reaching the end of its life, the next time it is switched on, it just trips again.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Dec 01, 2009
My Dyson DC35 stops after the first minute. Then it keeps stopping every few seconds. I checked for obstructions, washed the filter and cleaned the brush. Is it the batterie?
In the inlet pipe, there is a small valve that can get jammed shut with debris this causes them to pulse start, stop, start, stop, and so on. Ensure this is floating free, not jammed shut, it works purely on gravity... The other possibility is the cyclone needs cleaning. Remove the filter and check no dirt is lodged there. Remove the top torx screws and keep them safe. Carefully remove the top check for damaged seals gaskets etc (this can cause a malfunction). Again keep safe. The cyclone can then be inspected for dirt and dust clogging holes and airways. Clean thoroughly and reassemble, make sure all components are dry if they have been washed to clean them. Hopefully, this will restore the machine to working order
Feb 09, 2018 | Dyson Vacuums
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Can the filter be cleaned or does it have to be replaced. If it can be cleaned; how do I clean it?
Foam or cloth filters can be washed. I wash by hand with hot water and dish washing liquid, rinse with clean water, thoroughly dry and refit. Has always worked for me. The paper filters obviously can't be washed, but if you have access to a compressor you can blow them cleaner. Be careful as they do rip easily and this method only partially unclogs them. Replacement is the best way.
Apr 18, 2016 | Filter Vacuums
How to clean filter
The filter is usually replaced or washed.
Mar 03, 2015 | Filter Vacuums
How do I clean the filter
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
Sep 27, 2014 | Bissell 2 Sets Bagless Upright Vacuum...
I have a DC04 and when i switch it on it works for 10-15 mins thens stops working for about 20 mins then starts working again.
Your vacuum is overheating - that's why it cuts out. You need to check everywhere possible for blockages and also make sure the washable filter is clean and dry. If the machine has been run without the washable filter in place, then the exhaust filter will be clogged and will have to be changed too.
Feb 17, 2010 | Vacuums
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Shuts off after about 10 mins.
Hi!  This is the sign of a machine that is overheating, and almost certainly is caused by a partial blockage.  You need to check all the pipework and make sure the washable filter is clean (if you wash the filter, use only clean cold water, no detergent, and let it dry in a warm place for at least 12 hours, do not force-dry). I hope this helps.  I value your feedback, so please remember to rate this response. Good luck!
Feb 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
64 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
