Question about HP Color LaserJet 2600n Printer
Paper won't feed through
I have recently purchased a canon pixma ip2600 printer. currently it won't feed the paper through to print and i can't see that there is anything clogging the roller. Any ideas please?
  • 630 Answers
So why did you log this in the HP product pages? Try cleaning the rollers with a contact cleaner or alcohol based cleaner
Posted on Nov 18, 2009
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Ip2600 printer will not feed 1 paper at a time. feeds all paper that's in the printer at once.
That your printer roller problem. please repair it by a professional technician. thanks
Apr 10, 2011 | Canon PIXMA iP1200 Photo Printer
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Paper not feeding right
you need to take all of the paper out then fix the paper so it is all aligned then place the paper back into the paper holder still all aligned this should then prinbt properly
Jul 22, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper not feeding through printer
you will need to reallign the rollers,
try searching google for the service manual and it will tell you how to do it :)
thanks
alex
May 06, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I have a Canon iP2600. For no apparent reason, it stopped feeding paper on the left side only. On the right side, the paper catches, and tries to feed, resulting in a paper jam.
Sounds like an obstruction of some sort. Have a look on the left side with a flashlight as best you can, and see if maybe a staple or paperclip got lodged in there.
Apr 27, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
HP Color LaserJet 2600n Printer Logo
149 people viewed this question
Seeker5211
Seeker5211
