Question about iRiver PMP-120 Digital Media Player
Will not power up
Got from a friend who couldn't get it to work, i plugged a 5.0v charger to it and a green light comes on bt soon fades out, can i charge it by usb from my pc? when i hook it to my pc by the usb port the same green light comes on but still no power up?
  • 593 Answers
The battery is probably shot. Check voltage. if it is 0.0 then the battery has shut down internally and either needs to be charged for 48 hours, or replaced. Seems these batteries will shut themselves down to protect themselves and sometimes are never able to revive. You can try and charge it from the USB, but I dont think it does that, you need a 5.0V 2A power supply with the proper tip. I think it is a 3mm + center post. You can also remove the battery and check the pins when it is charging, It shoould show some voltage. Also, I dont think you can run it while charging.
Posted on Mar 09, 2008
Why does my garman not come on when plugged into car power source, and power light shows green light?
Your car adapter wiring might be faulty.. Green light shows it is receiving power from your cig socket but there isn't any power from the adapter to the plug to your gps..
Jul 19, 2014 | Garmin nuvi 1450 GPS Receiver
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
My laptop charger to acer 5930 stopped working in the middle of the night. The green light on the power supply lights up clearly when I insert it into the outlet. But as soon as i plug in the charger to my...
Remove the battery and try again.
If the laptop works ok with the charger connected (with battery taken out), then the battery needs to be replaced.
Refer to user guide on how to remove the battery.
Jun 24, 2011 | Acer Aspire 5930 Laptop Charger...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
02 xda orbit..
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
4. Light should turn orange.
5. Wait a moment or two then power it on.
that might get it to work.
May 09, 2008 | O2 Xda IIs Pocket PC
iRiver PMP-120 Digital Media Player Logo
59 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
