Question about Fargo Persona C30 Thermal Card Printer
It prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as the ribbon passes) to printing overlay (sometimes skips overlay), but stopped short of ejecting to the output hopper.
    Problem Solver:
  • 11 Answers
Download the latest copy of the C30 firmware, Fargo created a fix by sending more power to the ribbon sensor. After downloading the new firmware, calibrate the ribbon covering the printer the best you can from light.
Posted on Jun 03, 2010
    Problem Solver:
  • 14 Answers
Run diagnostic utility which is given on installation cd
calibrate your ribbon sensor
do advance and reverse of ribbon motor
clean your printer path using cleaning kit
for downloads follow the following link if you don't have the utility
http://www.fargosupport.com/search_results.asp?pulldowntype=&all=1&printer=73&submit.x=24&submit.y=7
Posted on Jan 11, 2010
2 Suggested Answers
  • 254 Answers
SOURCE: it prints the yellow &
Have you checked the type of ribbon selected?
The best you could do is check the ribbon sensor if it's not occulted!
Posted on Aug 16, 2011
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
Please I have an oki printer C831 that's printing only yellow and black on any printing am using it to print please help
I would think you have broken ribbons cables to the cyan and magenta LED print heads. As all the heads are the same I suggest you swop the black and cyan print heads around and see if cyan prints and black does not. That will prove is the print heads are ok. If they are then the ribbon cables need replacing or they are dirty at the heads. It could be just a case of unplugging them, clean them, then plug them back in again.
Oct 21, 2017 | OKI Office Equipment & Supplies
It is shadowing yellow when I print
Most likely it's either a dirty printer, or a printer than needs a calibration performed.
Printing color cards is done with a series of passes using a ribbon that has a series of panels - yellow, magenta, cyan, black, and a clear overlay. The card is positioned; a panel is printed; the card is repositioned; another panel is printed; etc.
This color "ghosting" or "shadowing" happens when the card is not positioned properly at the start of one or more of the ribbon-panel print-cycles. This can occur when the card slips on dirty rollers, or there is a sensor or calibration issue.
Both procedures are documented in the user manual, and at the Datacard web-site. I'd perform the recommended cleaning first. If it's been a long time since cleaning, I'd do it more than once.
If that doesn't correct your issue, the next step would be to perform a calibration.
If it is still not performing properly after the above steps, you may need to have the device serviced, as a sensor could be failed or failing.
Mar 17, 2015 | Datacard SP55 Plus Two-Sided Printer
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have already printed more than 1000 cards on my printer. Now often it started some problem like it prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as...
I think all you need at this point in time is servicing the card printer, with some of the hardware components like the ribbon been replaced. try get a technician that will help you with this.
I wish you best of luck.
Dec 30, 2009 | Fargo Persona C30 Thermal Card Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Fargo Persona  C30 Thermal Card Printer Logo
1,088 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
