Question about Nokia 6100
Nokia 6100 contact service solution please - Nokia 6100
This tutorial will show you how to upgrade your iPhone 4 to iOS 4.3.1 without upgrading its baseband using TinyUmbrella for Windows.
Currently there is an issue with older basebands such as 1.59.00 and FW 4.3.1. Until ultrasn0w is updated, you will only see one bar under signal strength.
Please Note: This ONLY Works with the iPhone 4!
Step One
Download TinyUmbrella from here Also make sure to download the iPhone 4 iOS 4.3.1 which you can find here.
Step Two
Double click the downloaded TinyUmbrella.exe file.
If you get a Windows Firewall notification, check both boxes and click Allow Access.
Step Three
Make sure the device is connected, and Umbrella has detected the type of device and its firmware.
**If you haven't already saved your iOS 4.3.1 SHSH blobs then click Save SHSH. Make sure theynokia 6100 contact service solution please - 47534.pngully save before continuing.
Hit Start TSS Server and make sure you receive no errors.
Once The TSS Server is "running" successfully, umbrella willnokia 6100 contact service solution please - 47536.pngTunes. Leave TinyUmbrella Open. You can double check to see if the TSS server is running under the Log tab.
If you do receive an ernokia 6100 contact service solution please - 50103.pngOT continue. Your restore will not work if the TSS server cannot be started.
Step Five
Open iTunes by doubling clicking its icon.
Hold down the Shift key and click Restore
Select your iPhone 4.3.1 firmware filenokia 6100 contact service solution please - 50098.png popup window that appears and click Open.
Click Restore to begin restoring your devicnokia 6100 contact service solution please - 50099.png 50098.png
Step Six
iTunes should give you error 1013. This is what we wanted, as it notes the baseband has not updated :) Click Ok and close iTunes.
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are nokia 6100 contact service solution please - 47454.pngith a device OTHER than iPhone 4.
Step Seven
Place your iPhone into DFU mode by holding down both the Power and Home buttons for ten seconds, then release the Power button and continue holding the Home button for another 5 seconds. You can find help with DFU mode here.
47454.png Step Eight
Fix Recovery in TinyUmbrella is currently not working.
Download this standalone .exe file to fix recovery on 4.3.1. Extract the file and double click on fixrecovery43.exe. A command prompt will open, and the program will go through the process. During this time, you will notice scrolling text on your iPhonnokia 6100 contact service solution please - 50102-500.png 50101-500.png
Step Nine
Your iPhone will now be on 4.3.1 with the 1.59.00 baseband! (Which means you can now unlock using this tutorial)
**Thanks to semaphore for his work on this tool
Posted on Apr 07, 2011
4 Suggested Answers
  • 3 Answers
SOURCE: contact service of nokia 6100
Hi
Instead of flashing you can unlock your mobile by using codes.you Can get free codes from http://www.unlock-free.com/nokia/nokia-6100.html.Try this dude.
Posted on May 24, 2011
PungaA
  • 91 Answers
SOURCE: Nokia 6100
Contact Service ... There something seriously wrong with your phone and it needs technical attention.
Posted on Oct 05, 2007
SOURCE: Nokia 6100
try to freshen up ur fones memory by removing ur battery and sim.if it still persist,go to BISMARK TELECOM
Posted on Oct 17, 2007
Contact service of nokia 6100 flashing ok but ui settings not responding
Hi
Jan 24, 2011 | Nokia 6100
I want to unlock my nokia 6100 could anyone help please
Ya it's simple..You get the unlocking service from any of the online sites..After that you follow the unlocking instructions here http://www.mobileunlockguide.com/mobile-phone/16771/nokia-6100/ .This site gives you the complete guidance..Using this you can unlock your mobile easily..
Nov 29, 2009 | LG KU990 Viewty
I NEED SECURITY RESETTING CODE FOR DCT-4
You can get master code for the specified DCT4 model from the following link
DCT4 1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650 3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111 6220 6230, 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260 7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
http://www.unlockme.co.uk/master.php
Please rate this solution
Rnj VINODKUMAR
Oct 15, 2009 | Nokia 2310 Cellular Phone
Nokia 6100 keystrokes to copy numbers from phone to SIM
use pc suit and copy the contacts to pc...
Aug 11, 2009 | Nokia 6100
How to format nokia 6100
Please do this.Type *#7370# in your mobile phone,it will ask whether you want to restore factory settings give yes and it will ask for the code the default code is 12345.Give the code and wait for some time your phone will restart and you will see that your factory settings are restored.kindly rate me if i had helped.
Jun 27, 2009 | Nokia 6100
Distribution
nokia service contact
Jan 17, 2009 | Nokia 6100
Puk code on nokia rm162x phone
The puk code is provided by the service provider.Please call the toll free customer service and any agent might help you out with this problem.Its nothing to worry about.Also they might ask you some details regarding the phone call log such as last outgoing call or etc.Pin code is related only to the service provider and not the phone.If you are using AT&T sim, contact AT&T customer care now.Repeating again, its nothing to worry about.I say this because I have seen people disposing their sim just because of this problem,Please do post your comments.All the best.
Jan 13, 2009 | Nokia CINGULAR 6100 Flexible Mini Boom W/...
Nokia 6100
Sep 25, 2007 | Nokia 6100
Nokia 6100
Sep 25, 2007 | Nokia 3100
Nokia 6100 security code error
IMEI: 353396/00/622606/7
MODEL: 6100
DEAR SIR SWICH ON SECURITY CODE
Aug 14, 2007 | Nokia 6100
Nokia 6100 Logo
2,136 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
