Question about Home
No water comes out of the tap connected to the rainwater tank when turned on
    Sergeant:
  • 399 Answers
Hi chances are silt is sitting in the bottom of your rainwater tank best bet is to memove the tap and flush out hope this helps
Posted on Nov 18, 2009
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
Water from house pump tastes of chemicals. It is coming from the pump.
It can be replaced with a metal one if you can locate a metal one that is the same.
What brand/model of pump do you have? You may have a well pump or a pool type pump?
Jan 07, 2016 | Plumbing
How to fix a household rainwater pump?
Pump maybe blocked or faulty. Check filters and flow.
Nov 24, 2014 | Washing Machines
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Why no water will come out of the water heater
Is there a shutoff on the hot water line coming out of the tank? Is this problem only at one tap or all of the taps in the house? Is the cold water supply to the tank turned off? If it is no water will flow since the cold water pressure pushes the hot out of the tank.
Aug 29, 2014 | Water Heaters
Davey HP45-05 with Rainbank will not turn off?
Hi Sam,
Combined Electrical in Fyshwick ACT here. Has your problem been resolved?
We have found that a leaking cistern which can only be a few litres a minute can cause this problem.
Aug 14, 2012 | Plumbing
I have a Rheem Optima 401 series hot water tank which has started leaking from the top of the tank and dripping warm water down the side. I have now switched off the water supply to the tank. We have a...
Yes, turn off leaking water heater because it might rupture.
Sounds like the tank is rusted and needs to be replaced.
Open following link:
http://waterheatertimer.org/Leaking-water-heater.html
For your next water heater, read following information
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 25, 2011 | Rheem Water Heaters
Last week my electric power went off for about one hour, in my kitchen I heard water rushing out my drains. when the lights came on I had no water.The well man came and said he had to turn my pressure...
It sounds like the bladder in your pressure tank is water logged. Turn your pump off and open a tap and let the pressure off. Once the water has completely stopped coming out of the tap go to your pressure tank and pump air into it. There should be more water come out of the tap. Continue to pump are in until you reach the pressure recommended for your tank and there is no longer water coming out of the tap. Close the water tap and turn the pump back on and this should fix the problem. If it does not you will probably need a new pressure tank. The bigger the pressure tank you have also will make the pump work less. I prefer a smaller one myself as there is less change in the shower pressure when the pump cycles than with a bigger tank but this is just a matter of prefference. Some people prefer a larger tank as it uses less power by the pump not working as often.
Mar 15, 2011 | Plumbing
No hot water pressure
There are heat sync balls in the nipples of your cold and hot water lines on your hot water tank. Cut the water lines and remove these balls as sometimes they come loose and float to the point where your water line connections to the tank are causing the pressure to drop when your tap is turned on
Feb 11, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Home Logo
584 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
