Question about Sony Cyber-shot DSC-W35 Digital Camera
Hai my camera was not working with flash even its on flash mode on
Fujifilm Finepix AX Flash Is Not Working/Turning On
If your camera is in "silent mode" the flash will not work. Press and hold the Disp/back button for a few seconds and the camera will toggle between "silent mode" and "normal mode"
Oct 09, 2014 | FUJIFILM Cameras
Why wont my flash work?
I'm sorry that the flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
- When shooting MPEG movies - When shooting in the Twilight or Handheld Twilight mode - If shooting with the Burst or Multi Burst mode - Shooting with Sweep Panorama - Shooting with the Fireworks or High Sensitivity mode. - If an external flash is connected
Please make sure that the Camera is not in any of the above modes.
If the issue persists, try resetting the Camera and check the operation.
Mar 06, 2012 | Samsung BL103 Digital Camera
DSC-55 camera flash doesn't work even though in Flash "Auto" setting in Easy or 'i' mode.
  1. When shooting MPEG movies
  2. When shooting in the Twilight or Handheld Twilight mode
  3. If shooting with the Burst or Multi Burst mode
  4. Shooting with Sweep Panorama
  5. Shooting with the Fireworks or High Sensitivity mode.
  6. If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
  • If the issue persists, please reset the Camera and make sure that battery is fully charged.
  • If the issue persists after performing all the above-mentioned troubleshooting steps, service is required.
Thanks for understanding.
Mar 13, 2011 | Sony Cameras
I can not change the flash setting on my camera
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected
Try initializing the Camera. To initialize the Camera, please use the Initialize option under Main Settings 1 Menu of the Camera.
Feb 22, 2011 | Sony Cyber-shot DSC-H9 Digital Camera
The flash will not come on
Feb 21, 2011 | Vivitar ViviCam 5022 Digital Camera
Camera does not flash, even when set to "always flash"
When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode Shooting with Sweep Panorama Shooting with the Fireworks or High Sensitivity mode. If an external flash is connected.
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
Jan 27, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Flash does not work no apperant cause
Jan 22, 2011 | Kodak EasyShare Z612 Digital Camera
The flash won't work even though set correctly according to the manual
If you feel that the above Troubleshooting steps helped you. Please rate my answer positively.
Jan 09, 2011 | GE C1033 Digital Camera
Flash is not working
Dec 31, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Sunpack pz40X II flash - compatible with Nikon D40?
hai i think u told only sometime....
may b ur settings are not rit in the cam.
Jan 07, 2009 | Sunpak PZ40X II TTL Flash
Sony Cyber-shot  DSC-W35 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
